RAM AIR V ENGINE
RAM AIR V ENGINE
MARODSKI MARODSKI
New User | Posts: 7 | Joined: 03/08
Posted: 03/31/08
09:06 PM
ram air v can any body tell ME what these part# and hand stamped code mean? crank shaft #ds-1363 & stamped RA2912,BLOCK#481988 I211 STAPED X-303-1-1,3.00" MAIN,OVERSIZED DISTRIBUTOR HOLE,DRY SUMP OILING,4.120 BORE,LONG ROD 7.08"THIN SHANKED,PISTON#207-99,INTAKE DS1201 W/SPACER PLATES,HEADS#44.  WHAT DO I HAVE???
Posted: 04/01/08
06:07 AM
what is the two letter code on the front passenger side of the block just below the head
MARODSKI MARODSKI
Posted: 04/01/08
06:59 AM
X-303-1-1  the motor came out of texas a was told
it was a 366cu used in nascar
Posted: 04/01/08
08:39 AM
Ok sounds more like a 400 to me the heads are 1969 R.A.4 with 2.19/1.77 valves the code you are giving is not in any of my books it should be for example a ww,ya,xp or somthing like that.
MARODSKI MARODSKI
Posted: 04/01/08
10:18 AM
the castig # on the block is 481988 which is a 71-74 400cu this block is not like any other 400 it's a twin to my 74sd455 the valves 2.25 int dia.& 1.88
ex dia. the head were benched at 354"& 246" @.750
on the valve lift. the code is in the factory location X-303-1-1
MARODSKI MARODSKI
Posted: 04/02/08
07:23 AM
Icon QuoteMARODSKI:
anybody? know of any of these numbers maybe a direction to look books ? websites ?
GP76 GP76
New User | Posts: 6 | Joined: 04/08
Posted: 04/04/08
07:40 PM
I did a search on yahoo for pontiac nascar engines it came up with a site that has some info on the 366 didnt see any casting numbers though the site I looked at is http://en.wikipedia.org/wiki/Pontiac_V8_engine I read that the 366 is basded on a 1969 303 RA V Tunnel Port 546184 2.11/1.77 56cc
andrzej andrzej
New User | Posts: 4 | Joined: 04/08
Posted: 04/05/08
04:52 PM
what i found out is that the ram air v  was made in 1969 under the following codes ....WI...WY....XY...XW, hopes this helps.
andrzej andrzej
Posted: 04/05/08
04:58 PM
Icon QuotePontiacman8:
andrzej andrzej
Posted: 04/05/08
05:19 PM
Icon QuoteMARODSKI:
couldn,t find anything on the crankshaft but i did find out something about the block. if it were a ram air v the engine casting should have read 9792968 1969 4 bolt, not 481988 which is a 1971 400.the intake should have a casting number 545288, and for the cylinder heads 44 are ram air v 375 hp.
MARODSKI MARODSKI
Posted: 04/06/08
12:44 PM
This block is dated , I211 therfore cast september,21ST
1971. the back of the block is fitted for dry sump oiling,4.120 bore,3" mains,center crankshaft oiling ,see pgs,59."'72 366 block".  pgs,212."366 c.i.d.rods,303 forged crank",7.08" rods,  pg,214. "72 cc fully machined heads #44".(as seen in pete & johns book)i can mail pictures to any won that my have some knowledge in the ra V program during the 70's, & the hand stamping of factory style codes. thanxxs....
transam303 transam303
Posted: 04/20/08
01:52 PM
What are your plans for this, looking for 303 cranks,blocks, rods. I road race a 70 t/a in vintage,thanks Gary
Doug63 Doug63
Posted: 04/29/08
09:25 PM
I will say that you have a product of creative engineering, an experimental 366 fitted with the tunnel port heads. You have RA V tunnel port top end or at least the components. The Intake DS 1201 is a tunnel port manifold for the Short Deck RA V 303 block that are 1 1/8” shorter then the standard Pontiac deck of the time. I am assuming the spacer plates you speak of were fabricated to take up space between manifold and heads to fit a standard deck height block. The #44 head casting number says they are RA V 400 tunnel port heads but that does not mean anything they could be off a 303/400 but not a 366 those were supplied with RA IV heads. I would CC the combustion chambers and if they turned out to be 53cc/67cc then they are the 303/400 heads respectively.
The rest of this is guess work that supports that you have an experimental 366. Your casting number for the block show it being a ‘73 400 which has 3” mains with a deck height 1 1/8” taller then the 303 block. You could but I doubt you have the 303 crank that’s a lot of risky work to weld up the journals to the 303 2.5” main or weld up the crank. A custom crank could be built to fit the block at a huge expense. In either case, this leaves the light weight 7.08” rods short by 1 1/8”. So this leaves us with the 366 for two reasons, first they had 3” mains and would fit into a 400 block, and second the 366 crank has a 3 3/8” stroke and with 455 wrist pin placement style pistons the 7.08” rod were used.
MARODSKI MARODSKI
Posted: 05/04/08
02:07 AM
A product of creative engineering,well said! now if i could find the engineer.The heads have machined combustion chambers & are 72cc #44 on head between center exhaust ports. Block #481988 is cast almost identical to my 1974 455sd #490132 block, with the exception of the cam driven dry sump oiling provision being fully machined and functional on the #481988 block. also front of block stamped x-303-1-1 and appears to be same style stamped on factory ram air and SD stuff. crank is factory forged part# ds-1363, and also hand stamped RA 2912 on first & third crankshaft counter balance weights.
