Cylinder installation questions
69GTOby 69GTOby
Guru | Posts: 1109 | Joined: 02/09
Posted: 02/19/09
10:49 AM
I got my #13 heads back from the machine shop and I am working on reinstalling them on my '70 400 in my '69 Goat.  I have a few questions:
The intake gaskets cam with 2 block off plates.  Should I use them?  I think they go on the center ports.
After I get it all together and run the engine for the first time in quite a while, should I re-torque the heads again after a heat cycle?
Should I use any kind of sealant on any of the head bolts?  My '69 Pontiac manual says not to use any, the head gasket set from Mr. Gasket said otherwise.
Should I put oil on the push rods?  On the rocker arms?  Anywhere else?
Thanks in advance!!
Moderator | Posts: 5769 | Joined: 02/08
Posted: 02/19/09
12:10 PM
Those block off plates are to block the exhaust cross over If it was mine I would get some felpro head gaskets I always had problems with the MR gasket head gaskets leaking and they tend to blow pretty easy on high per formance applications.
No there is no need to use sealant on the head bolts because they do not go into the water jacket like the chevy engines.
Just prime the engine and you will be fine.
69GTOby 69GTOby
Posted: 02/19/09
01:03 PM
So, use the block off plates?  I don't need exhaust running through my intake manifold.
Prime the engine??
Well, I wish I was advised to use Fel Pro head gaskets instead of the Mr Gasket ones.  Oh well, too late now.  That's okay, I'll have the engine out to build the lower half of the engine when the time comes anyways.  We will see how the lower end holds up to the new heads.  I might be back into the engine sooner than later, in which case, Fel Pro gaskets will be utilized.  Thanks for the advice!
Posted: 02/19/09
01:48 PM
The block off plates will keep the heat out of the intake there for making a little bit more power but will also take longer to warm up also if you have the Q-jet that requires heat to open the choke then leave them out other wise the choke will not open.
Posted: 02/19/09
01:51 PM
Priming the engine is when you use a modified distributor or a oil pump priming tool which operates the oil pump to circulate and make sure that every thing has a coat of oil on it before it is started.
69GTOby 69GTOby
Posted: 02/19/09
02:47 PM
I have a holley 650 with electric choke on it, so I'll use the block off plates.
Should I go buy this oil priming tool you're talking about?
Thanks Pontiacman8!
Posted: 02/19/09
03:03 PM
You can make one if you have a old junk pontiac distributor by removing the gear on the shaft and the counter weight assembly on the top.
Posted: 02/19/09
03:03 PM
Your welcome.
69GTOby 69GTOby
Posted: 02/19/09
10:53 PM
Could I just coat the push rods with oil, and coat the rockers before I start it up?  Is the priming thing really mandatory, I mean coating the heads with oil would have the same effect as priming, right?
Posted: 02/20/09
12:02 PM
Yes you can just coat the push rods and rocker arms in oil.
If the engine has not been ran in a while then doing that is not going to help lube the bottom end basically priming the engine just makes sure that oil is circulated though the engine to minimize the change of damaging the engine due to a dry start no it is not mandatory but is extra insurance.
69GTOby 69GTOby
Posted: 02/21/09
10:03 AM
Okay cool.  Thank you sir.
Posted: 02/21/09
10:44 AM
Your welcome.
Posted: 02/21/09
11:47 AM
Any thing else just ask.
69GTOby 69GTOby
Posted: 02/21/09
04:26 PM
What is the torque spec for the rocker arm nuts?  My '69 Pontiac service manual says 20 ft lbs.  Is this correct?  I thought it was something about tightening them down until you can't spin the push rod in you fingers or something.
Is there a torque spec for the intake manifold bolts?  Is there a pattern or sequence?  I'm assuming not, but I wanted to double check.
This might be a stupid question, but what brand of oil should I put in it?  Is Advance Auto brand oil okay, or should I get something better?
Addict | Posts: 3298 | Joined: 01/07
Posted: 02/21/09
05:58 PM
Pontiac engines have bottle neck rocker studs, meaning the bottom shank of the stud is larger than the threads. The factory procedure is to simply torque them all down to 20 ft.lbs, this works fine with stock and mild cams assuming the heads haven't been milled excessively. Many people replace the standard rocker nuts with "poly locks" which have a collar that allows the nut to adjust the preload like the common Chevy method you refer to.
The intake bolts have a specific torque, check your manual to be sure. You must tighten the bolt that goes into the front of the manifold from the timing cover/water pump first to draw the manifold forward to seal against the rubber washer, then tighten the manifold bolts in a criss-cross pattern from the center out.
For the oil, I'm a strong advocate of Shell Rotella T diesel oil in traditional flat tappet engines. It is readily available affordable and has the high pressure wear additives missing from most automotive grade oils today. Do a search in the tech articles for full info on why this is so important. This is great topic to discuss at your trade school too.
