326 HO 4bbl
326 HO 4bbl
1BadTemper 1BadTemper
New User | Posts: 18 | Joined: 04/09
Posted: 04/18/09
11:17 AM
New to the forum and recently purchased a 67 Tempest Custom....Someone told me that the pontiac 326HO 4bbl has to be run on premium gas only. Is there any truth to that or is it just recommended to run on premium. Thanks,
Posted: 04/18/09
11:30 AM
What is the engine code found on the front passenger side of the block right below the head.
Posted: 04/18/09
11:54 AM
Not sure. Haven't picked up the engine. Would it be advisable to just keep the 326 2bbl and install an aftermarket 4 bbl intake and carb? Would I get a more accurate answer by disecting the numbers on the engine?
Posted: 04/18/09
12:04 PM
Ok the 1967 326 came with 9.2:1cr w/2bbl carb. and the 326 w/ 4bbl came 10.5:1cr.
With iron heads you will need premium gas for the 9.2:1 and race fuel for the 10.5:1cr with iron heads to prevent detenation.
Posted: 04/18/09
12:19 PM
So no matter what I do I'm running premium fuel unless I go with the 326 4bbl, then I have to run race fuel. thanks, makes my decision easier since I dont plan to race it just make it sound good and cruise it.  Will a mild cam give the 326 2bbl some power or is it not worth it and just go with a bigger engine?
Posted: 04/18/09
02:02 PM
Your welcome.
Posted: 04/18/09
02:13 PM
Yes it will respond to upgrades for a cam I would recomend a lunati P#Lun-00072LK which has a .458 lift and a RPM range of 1500-5000 or Crn-105072 which has a .454 lift and a RPM range of 1800-5200.
Posted: 04/19/09
08:42 AM
Appreciate all the help Pontiacman and will be putting in thst lunati cam. More than likely i'll be back with more ????'s
thanks again
Posted: 04/19/09
10:26 AM
No problem anything else just ask.
Posted: 04/21/09
08:44 AM
Would that same cam work for the 4bbl 326 or would you recommend using something else? Thanks
Posted: 04/21/09
08:53 AM
It will work just fine with the 4bbl 326.
wldman46 wldman46
New User | Posts: 19 | Joined: 07/09
Posted: 07/09/09
08:02 AM
I have a 66 lemans with the 326.only changes are replacement of timing chain every 3-4 years hei with accel coil msd 6a ignition 69 q-jet intake and a crane blueprint S cam it is the 9.2 cr engine runs just fine on 89 octane.the cam has more to due with fuel req.overlap and centerline.If you dont think its true ask people with  engines that are close with one difference say one with 109 and the other with 114 centerline camshafts.this is where advertised and static comp comes in.the fuel req. will be different.hope this helps.
Posted: 07/09/09
11:49 AM
That's an important point to consider concerning compression ratio, octane requirement and camshaft specs. What wldman46 says is partially true, a camshaft with more overlap will bleed off cylinder pressure at low rpm under low load and light throttle, which allows the engine to use lower octane fuel for a given cr. The problem arises when you jump on the throttle at 2000rpm at low speed and force the engine into full load conditions. At about the time the engine starts to reach peak torque, as determined mainly by the camshaft, the cylinder pressure is at it's peak. That's when detonation happens if there isn't adequate octane. You may not hear it with that q-jet howling and the flowmasters bellowing, but it can still be there pounding the top shell of the rod bearings, the bottom shell of the mains, ringing thru the crankshaft and hammering the top of the piston down on the top piston ring. That's why the rule of thumb of removing the decimal point from your CR and using that as your octane requirement is so much easier than rebuilding a detonation destroyed engine. A lot of other factors come into play as well, fuel/air ratio, engine temperature, humidity and ambient air temp for example. Personally, I'd rather play it safe and be sure when I build it the first time.
Posted: 07/09/09
12:01 PM
ya some people don't realize that a bigger cam or one with more over lap and/or center line only bleeds off pressure it low RPM and low speeds.
That is a great point that barney had with removing the decimal point from your CR and using it as your octane requirement.
There are a lot of people that will tell you it is ok to run more than 9.5:1CR on 93 octane pump gas but that is just not true.
