motor mounts
Posted: 08/16/09 01:42 PM
Can anyone tell me where to get the plate that bolts to the block of a pontiac 400. Someone tried to fabricate some because the car previously had a 301. I have the motor mounts but need the mounting plate. Will i have to go to a junk yard. Its hard to find 400s anymore. Any thoughts?
65pmdgto1
Posted: 08/16/09 08:49 PM
I think Ames and Performance Years both sell what you are looking for.
Puddles
Posted: 08/17/09 03:48 PM
You can try classic industries to. It depends on your application also. I converted my 69 Firebird from a 6 to a 400. The 400 was a 70 block so I did not need the plates. So depending on the year of the block and the year of the vehical you may not need them.
Posted: 08/19/09 06:19 AM
I think that might be part of the problem. The car is a 77 grand prix, but the block came out of a 68 bonneville. I will give classic industries a call. Thanks
Opontee
Guru
Posted: 08/20/09 12:28 PM
I was going to say that I have some, but they fit a Firebird. Won't fit an A (?) body.
 Anna Mae quit.
Posted: 08/20/09 02:36 PM
Yea, i dont need the adaptor plates. I need the engine mount for a 1968 bonneville. The mount that bolts to the block. Cant find one anywhere. Thanks anyways.
Opontee
Guru
Posted: 08/21/09 12:14 PM
Try this
http://www.jbp-pontiac.com/products/fasteners/motorMounts.htm
WRP-MM6 Engine Mount Adaptor Kit to put Pre 1969 Engines in 1970 & Up Chassis $49.95
Probably the only way you can do it.
 Anna Mae quit.
Posted: 08/21/09 01:44 PM
Opontee is right you need the adapter kit so you can put the 77 Grand Prix brackets on the 68 block and still use the 77 frame mounts. There is no way that the 68 brackets will bolt onto the 77 frame mounts. Steve
Posted: 08/23/09 05:19 PM
Ok, I have the adapter kit to move the mounting holes forward. What i dont have is the mount that bolts to the adapter. I think i need the 77 brackets for a 400. I have the one that bolts to the frame. I dont know what is supposed to go in between.
Posted: 08/23/09 07:49 PM
I believe the brackets from the 301 will work (using the adapter plates), if you don't have them anymore, any brackets from any Pontiac V8 after 70 or 71 will work. Assuming your car has the captured rubber mounts on the frame. Steve
Opontee
Guru
Posted: 08/25/09 08:50 AM
I know the GP engine brackets are taller than the firebirds. I had a friend that tried to use GP mounts in a Firebird and the engine sat to high. Luckily for him, I had a set for a FB. So I guess what I'm saying is, don't get them for what the engine is, get them for what the car is.
Does any of this make sense?
 Anna Mae quit.
Posted: 08/25/09 01:55 PM
My 1979 Formula (1975 Pontiac 350)uses the engine block brackets from a 1976 Lemans wagon with a 400 (the 400 was cracked, but I used the Th400 from the wagon) and it bolted in on the factory 301 frame mounts. The 1973 to 77 Lemans and GP used the same frame(except the side rails were longer on the GP) so there shouldn't be a problem. The firebird mounts that came with my 350 were identical but were too rusty to use. Steve
Posted: 08/27/09 06:41 AM
Thanks for all your help. I am going on vacation, i will find some mounts when i get back.
