1975 quadrajet vaccume lines?
sddustinfrye sddustinfrye
New User | Posts: 3 | Joined: 05/10
Posted: 05/03/10
09:13 PM
I have a 1977 T/A with a new build on a 400. I need help hooking up the vaccume lines on the carb. It is 1975 quadrajet. If anyone could tell me what goes to what or even have some pics that would be great.
Guru | Posts: 1251 | Joined: 02/10
Posted: 05/04/10
10:51 AM
If you have a Chiltons manual for your car, it will show where all the lines for you make/model should go. The rest of the vacuum ports can be plugged. Also, a google search might show you where they go. It varys from make/model/year so it's hard to determine exactly where by your description.
My 71 has 5 major hook ups for vacuum lines.
1. from the heater/A/C control
2. from the distributor
3. from the vacuum assisted brake booster
4. the PCV valve
5. The gas tank recirculation canister
1-3 I have hooked up to the back below the throttle butterfiles to see vacuum all the time
4 and 5 I have hooked up to the front before the butterflies to see vacuum when ever I apply throttle.
Posted: 05/04/10
11:42 AM
Ok thanks. I think the vacuum ports on my carb are set up a little different than yours but I think as long as they are all getting a vacuum from somewhere it should be fine.
waynep7122 waynep7122
Posted: 05/04/10
06:32 PM
more info is needed....
autozone has a bunch of vacuum diagrams for these...   you have to join and log in... on the upper right corner of the web page... then select your car....   just above where you selected you car at... when logged in.. you will see a repair info link in blue...    the vacuum hose diagrams are at the bottom of the drivability and emissions section..
here is a list of the images..
Fig. Fig. 13: Vacuum hose schematic 1975 350 Federal engine with 2-bbl. carburetor and AIR system
Fig. Fig. 14: Vacuum hose schematic 1975 350 and 400 Federal engines with 4-bbl. carburetor and manual transmission
Fig. Fig. 15: Vacuum hose schematic 1975 350 and 400 Federal engines with 4-bbl. carburetor and automatic transmission
Fig. Fig. 16: Vacuum hose schematic 1975 350 and 400 California engines with 4-bbl. carburetor
Fig. Fig. 17: Vacuum hose schematic 1975 350 engine with 2-bbl. carburetor and without AIR system
Fig. Fig. 18: Vacuum hose schematic 1975 400 Federal engine with 2-bbl. carburetor
Fig. Fig. 19: Vacuum hose schematic 1975 455 Federal engine with 4-bbl. carburetor
Fig. Fig. 20: Vacuum hose schematic 1976 250 Federal engine with 1-bbl. carburetor
Fig. Fig. 21: Vacuum hose schematic 1976 250 California engine with 1-bbl. carburetor
Fig. Fig. 22: Vacuum hose schematic 1976 350 and 400 Federal engines with 2-bbl. carburetor
Fig. Fig. 23: Vacuum hose schematic 1976 350 and 400 California engines with 4-bbl. carburetor
Fig. Fig. 24: Vacuum hose schematic 1976 400 Federal engine with 4-bbl. carburetor and automatic transmission
Fig. Fig. 25: Vacuum hose schematic 1976 400 and 455 Federal engines with 4-bbl. carburetor and manual transmission
Fig. Fig. 26: Vacuum hose schematic 1976 455 Federal engine with automatic transmission
Fig. Fig. 27: Vacuum hose schematic 1976 455 California engine
Fig. Fig. 28: Vacuum hose schematic 1977 301 engine with manual transmission
Fig. Fig. 29: Vacuum hose schematic 1977 301 engine with automatic transmission and without AC
Fig. Fig. 30: Vacuum hose schematic 1977 301 engine with automatic transmission and AC
Fig. Fig. 31: Vacuum hose schematic 1977 350 (code P) and 400 engines with automatic transmission
Fig. Fig. 32: Vacuum hose schematic 1977 350 (code R) and 403 low altitude engines
Fig. Fig. 33: Vacuum hose schematic 1977 350 (code R) and 403 high altitude engines
Fig. Fig. 34: Vacuum hose schematic 1977 350 (code R) and 403 California engines
Fig. Fig. 35: Vacuum hose schematic 1977 400 engine with manual transmission
Posted: 05/04/10
06:46 PM
one more thing...   look around on your car.. there should be a vacuum diagram pasted somewhere ... radiator core support.. fan shroud..  air cleaner.. inner fender wells...   probably not on a valve cover..
take a good picture of it...    post it to one of the photo post web sites... post the link....
post the pictures of your engine also... and 5 views or more of the carb...   do you still have the 77 carb???
there might be differences..
post carb numbers...     stamped in the right side of the main body..    170????? the second row also.. that gives the date code...
and.. does your car have to pass a smog inspection.. visual and sniffer test????
Posted: 05/05/10
11:08 AM
Thanks, That should help a lot. Ill take a look at those diagrams. I pretty much had to buy almost all new parts for this car so most of the parts you listed that would have a diagram on them did not come with the car when in bought it. All that i have is the one carb and I think its a 74-75 model. Ill take a picture of the carb and engine. Also, no smog inspection needed.
