Pontiac 301 upgrade (?how good will this work?)
81_301
Posted: 09/18/10 07:55 PM
hello to everyone, well first thing i have to say is im new to this website, and i own a 1981 pontiac trans am with the original 301 (non-turbo) and 200 turbo-hydromatic transmission. The car is pretty clean and apparently has been garged kept for most of its life considering there is little to almost no rust or bondo on it. Anyway, back to the reason i am posting this. I would like to eventually rebuild this engine with an increase in power. At first i thought about taking the 301 out and putting a 400 in it, but i thought about that and didn't really like it considering how many times i read on people putting down on these engines, I defintitly want to keep the 301. It seems like I want to in a way defend the fact that the 301 isnt that bad,
ANYWAY, after reading ALOT of different fourms and suggestions, I have come up with this formula for rebulding it,
-comp cams 252h (with the lifters that come with the cam off comp cams's website) -bore out to the next size(not sure what size it is right now) -shave heads -hotter ignition system with better distributor
(The next couple im not to sure about and need some kind of feedback on) -?holly 650cfm carb or keep Q-jet? -?headers or bigger exhaust manifolds? -?x-pipe or straight pipes? -the only other thing im not sure are if i could get some kind of roller rockers for it
Well, if your still reading (sorry about the length of the post) any kind of feedback would be greatly appreciated. Thanks,
69GTOby
Guru
Posted: 09/18/10 09:41 PM
That is a good cam choice for the 301. Only bore it out if you have to, and only shave the heads if you have to. If it already has an HEI distributor, keep it and just upgrade it - hotter coil, timing advance tuning, etc... If your Q jet works well right now, keep that, if not a Holley 600-650 cfm carb should work well. I would use headers for sure with an x pipe, 2.5". You could get some full roller rockers, Harland Sharp, that'd be nice, or just keep the factory pressed steel units, they'll be fine. That's my .02.
**** 1969 GTO resto in progress. '76 350+.060, #13 heads, 9.2:1 CR, Lunati cam, Edelbrock Performer, 750 Holley, HEI, Ram Air manifolds, 2 1/2" exhaust. TH400 trans w/shift kit and 2400 stall. 235/60/15 front, 275/60/15 rear on Rally II 15X7s. GM 12 bolt posi with 3.73's.
Posted: 09/19/10 05:07 AM
Glad to see you did some homework before firing off a new post, makes it easier for the rest of us (I don't type too well and I hate re-typing everything a dozen times!). Sounds pretty decent to me, although I would stick to the Q-Jet simply because the only way to put another carb on is with an adapter plate. Yes, Holley has a spreadbore 650cfm, but the most this engine will ever need is a 600 and yes, the Q-jet is likely a 750, but it will only flow what the engine requires. When it comes to exhaust, stick to 2.25" pipes as max unless there is a chance you will swap in a larger engine in the near future, even with a mild 400, 2.25" will be fine. An X or H pipe will help torque and make the exhaust sound smoother but probably isn't a necessity for a 301. If you still have a catalytic converter and want/need to keep the car legal, use a pair of universal fit 2.25" in/out honeycomb cats, they are a huge improvement over the old pellet cat. As you've already figured out, the best move is to take what Pontiac gave you and just try to enhance it. Playing with distributor advance curves (try 12 degrees base timing, with another 20-22 degrees mechanical advance all in by 2500-3000rpm...set this with the vacuum advance unplugged, then plug it back in when done) and carb jetting (you can get tuning kits thru Edelbrock for the Q-jet) will make the biggest difference in the engine. Aside from the engine itself, there are two other areas to address for better all around performance...the rearend and trans. I don't know what gears you have now, but typical factory gears for 301/auto cars are in the 2.41/2.56/2.73/3.08 range. A swap to a 3.42 gear/posi will really improve around town response but will raise your highway cruise rpm to about 3000rpm @ 65mph depending on tire sizes. Here comes the solution! Swap in a mid 80's 200-4r automatic overdrive to give you great response and acceration around town and grandma-cruiser rpm at highway speeds. It is a bolt-in (mechanically) and there are kits from Shiftworks and Bowtie Overdrives available to convert your factory shifter to 4 speed auto detents, plus Bowtie has excellent info on their website on the correct means of setting up the TV cable so the trans will live a long life and shift correctly. The main drawbacks to these transmissions in the past was people didn't have that info and found that they wouldn't shift right and burned up when swapped incorrectly. Hope all this helps. Steve
Posted: 09/19/10 05:09 AM
Also there was an article a few years back that ran in HPP about the 301. I have it scanned and stored in my other computer (out for repair right now) and I would be happy to email it to you if you send me a PM with your email address. Steve
Posted: 09/19/10 06:29 AM
Ya that is a decent cam not much of a comp fan but that cam works great for the 301 I have used it in a few 301 Pontiac engine builds and it wakes the 301 up a *** I would not bore the block more then .040 over because those 301 blocks are thin .020 or .030 is what I usually have them bored to. Be careful how much you take off the surface of the heads I would just have enough remove to insure the surface is flat and true. I used the Harland sharp 1.5 full roller rocker on some of my 301 builds but you have to replace the bottle neck studs with 7/16 studs. Headers is a plus they will help that little 301 breath better. If you are set on getting a aftermarket distributor I recommend the Pertronix flame thrower HEI but the stock GM unit will be all you need just check it out and make sure the mechanical advance is not sticking and that the springs are in good shape. The Q-Jet will be just fine but if wanting to replace it a 450CFM Holley or 500CFM edelbrock will be all the 301 will ever need.
81_301
Posted: 09/19/10 10:13 AM
cool, thansk for the feedback, im pretty certain now on what ill do to the engine when i rebuild it, that shouldnt be for awhile though cause it runs pretty much perfect right now, i just thought itd be a good idea to start getting some info together so i could have a good game plan. right now im about to get the a/c working in it again, so it definitly is a cruiser, but again thanks to everyone for the feedback
Posted: 09/20/10 02:53 PM
No problem anytime.
Ross
Posted: 12/04/12 08:08 AM
If you still have that article I would love to read it.
Opontee
Guru
Posted: 12/04/12 09:05 AM
Put a 455 in it and tell everyone it is a 301, lol. Not many people can tell the difference anyway.
 Anna Mae quit.
