69 428 engine build
69 428 engine build
razorone razorone
New User | Posts: 5 | Joined: 12/10
Posted: 12/27/10
06:44 AM
I purchased a project car last fall. 67 242 car. no motor. I picked up a 69 428 4bolt std bore motor, good bores/good crank. My plan so far is h-beam rods, .030 Probe SRS -5.5 pistons, factory crank, 7K3 heads, (elderbrock alum still a posiblity) I'm shooting for 9.3 to 9.5 CR.    I wan't this motor to run as hard as possible on pump gas. It will not be daily driven but a weekend head turner.  If I go with the cast heads they will be ported. Roller rockers, 4 speed/3.55-3.70 gears.
Having problems with the rest. I've researched pontiac cams and I'm more confused that when I started. Roller cam or not? Best intake to use, 1.5 or 1.65 rockers. How much carb. etc. Open for any ideas and tricks.
Posted: 12/27/10
09:05 AM
Your 421 is from the Super Duty days and would have possibly had the McKellar #7, #10, or #041 cam grinds,,, (405 horse in it's day) the 068 was also a good cam then, a modern grind along those lines would be a great combo.
Tri power looks great on the warrior, as would dual quads.
Check out the link below,,,
www.highperformancepontiac.com/tech
Posted: 12/27/10
09:21 AM
Cylinder Head Vol (cubic in.) 5.856
Piston Head Volume (cc) Piston Head Vol (cubic in.) -0.336
Gasket Thickness (in.) Swept Volume (cubic in.) 54.106
Gasket Bore (in.) T.D.C. Volume (cubic in.) 6.424
Cylinder Bore Diameter (in.) Gasket Volume (cubic in.) 0.566
Deck Clearance (in.)Note: Neg. nubmer above deck, Pos. number below deck Deck Volume (cubic in.) 0.338
Stroke (in.)
STATIC COMPRESSION RATIO
9.422
Posted: 12/27/10
09:22 AM
I would go with the edelbrock RPM intake and port match it to the heads.
http://www.lunatipower.com/Product.aspx?id=2356&gid=297
This cam would work well with the RPM intake for your 428 used it on a couple of builds and works great if going with a hyd. flat tappet.
A single 850 DP Holley would work to deliver the fuel or if a dual quad set up is going to be used 2 450-500CFM carbs will work.
Mr.Milt Mr.Milt
Posted: 12/27/10
09:25 AM
You know that some people would mortgage there house for a 421 SD.  I would choose the Tri-power if I was lucky enough to have the engine.
Posted: 12/27/10
09:37 AM
I'm confuesed how do you get a 421 SD out of a 1969 428 with 7k3 heads ??  Confused
Posted: 12/27/10
09:44 AM
you don't.
But a 428 is nothing more than a 421 bored .028 over
Posted: 12/27/10
09:48 AM
A 428 stdbore with 7k3 heads would give you 8.83 CR . 30 over would be 8.94 CR  with dome pistons ?
Posted: 12/27/10
09:52 AM
Not with a negative volume on the pistons.
I guess he needs to post weather or not those are flat tops or dome pistons.
I'm think they are domes due to the -5.5CC piston head.
Posted: 12/27/10
10:09 AM
That would mean every 428 is a 421 SD ( stupid ) I don't think the real owners 421 SD engines wouldn't think so !
Posted: 12/27/10
10:26 AM
RAzor, I've got a 68 428 code YH I built for my 1971 242 car.
P-man listed a very good Lunati cam for hydraulic flat tappet. If you choose to go w/roller, several companies make good ones. I'm running a Crower mechanical roller w/crane magnum roller rockers. Bored the block .060"
I put on the E- performer RPM heads w/72CC chambers. Only thing I don't like about them is that the chambers aren't machined as Pontiac factory or the 87CC E heads.
The 850 Holley DP carb P-man mentioned would supply your air/fuel needs for anything under 6500 RPM. I went with dual quad set up (Offenhauser and 2 E-performer 500 CFM carbs) and set them up progressively. Calculations showed I would need aproximately 870 CFM at 6500 RPM. 7K RPM was a tad over 900 CFM (again if my memory serves me correctly)
You may want to get more input on the piston style. P-man and Tuff can weigh in on this one but I went w/flat tops in the belief that the dome would hinder flame propogation, slow it down and possibly loose some power output, but that's just my belief, others like them.
I used Eagle H-beam 4130 CM rods and Ross lightweight forged pistons. small end weight was something like 922 grams is all (If I remember correctly without digging up my data). I'm using the factory Arma steel crank and it's been shot peened (many many moons ago) and then the rotating assemble was balanced to 90%.
You can make some really massive torqu/HP with a 428.
what code is your block?
Posted: 12/27/10
11:15 AM
Icon Quotegtojack1366:
Here are the facts and figures Jack, settle down,,,
Pontiac
Monday, December 27, 2010
10:09 AM
Pontiac Engine Bore Sizes
Cubic Inches
Bore (inches)
Stroke (inches)
Main Journal size (inches)
Rod Journal size (inches)
265
3.75000
3.0000
3.000
2.250
287
3.75000
3.2500
2.500
2.250
301
4.00000
3.0000
3.000
2.250
303
4.1250
2.8400
3.000
2.250
316/317
3.93750
3.2500
2.500
2.250
326
3.71875
3.7500
3.000
2.250
347
3.93750
3.5625
2.623
2.250
350 (354)
3.8750
3.7500
3.000
2.250
366
4.1530
3.3750
3.000
2.250
370
4.06250
3.5625
2.623
2.250
389
4.06250
3.7500
3.000
2.250
400
4.12000
3.7500
3.000
2.250
421
4.09375
4.0000
3.250
2.250
428
4.12000
4.0000
3.250
2.250
455
4.15000
4.2100
3.250
2.250
As you can see, the stroke is mostly the same, only the bore changed,,,
Mr.Milt Mr.Milt
Posted: 12/27/10
11:24 AM
Sorry, I was reading something about the 421 SD and I guess I had a senior moment.
Posted: 12/27/10
11:44 AM
Icon QuoteMr.Milt:
Morning Milt,
Chuckles, I suffer from "oldtimers disease" too,,, sometimes
LOL
Posted: 12/27/10
02:39 PM
It's still stupid ! If I had a gold coin that was almost the same as the other one that makes them the same . No way ! ,A spade is a spade .A 428 is a 428 and a 421 is a 421 ,428 says 428 on the block not 421 ! Calling a 428 a 421 SD is a joke !  Smirk plus it had 1972 7k3 heads on it .I guess you could call them ram air 4 heads the specifications are almost the same ! Tongue
