Rocker Studs
Rocker Studs
big-g-67gto big-g-67gto
Guru | Posts: 905 | Joined: 07/10
Posted: 01/01/11
01:50 PM
I'm converting the rocker studs on a set of #16 1970 heads, from press in to screw in. The press in studs apear to be hollow, can anyone tell me why??? please...  Blush
I got that Tin Indian GRIN!!
Posted: 01/01/11
02:14 PM
They are called through the rocker stud oiling studs ! And are for oiling ! They are usually on older pontiac engines with no oil hole through the pushrod .Why they are on a 1970 head ? #16 1970 heads are small valve heads you might want to get a set of big valve heads . Wink
Posted: 01/01/11
03:01 PM
These heads are going on a 350 that I am freshing up, will the screw in studs need oil holes?? I've worked with big value heads and don't remember those haveing oil holes.
Posted: 01/01/11
03:12 PM
You shouldn't need oil studs if you have hollow pushrods and rockers to match . But I think you will have to use a 1/2 - 7/16 screw in studs because the hole is to big for a 7/16 base stud . I would send them to a machine shop !
Posted: 01/01/11
03:53 PM
Will do Jack thanks for your imput Grin
Posted: 01/01/11
04:00 PM
Icon Quotegtojack1366:
+1
Threading rocker stud bosses is a job for a machine shop, that tilts and aligns each hole for surfacing and tapping.
Posted: 01/02/11
09:09 AM
+1
Posted: 01/02/11
04:43 PM
Here's something I found out about the hollow studs - We pull the studs and install ARP 1/2" studs. With stock rocker arm ratios, the cast-in pushrod guide in the head works fine. Keep in mind the 1965 and later heads had the hollow rocker studs, but no oil passages . Why ?
Posted: 01/03/11
12:49 PM
The machinist found screw in studs, with the oilers, thru Northern Auto Parts. Grin
Posted: 01/07/11
08:05 AM
Got the heads back from the machine shop yesterday, they look great, new valve springs, new APR screw in studs with oilers. Plan to start putting the old 350 back together Sunday. Cool ....
Posted: 01/07/11
08:22 AM
yep
Posted: 01/13/11
01:38 PM
Put the heads on the 350 over the weekend, but couldn't get the rockers set, ran out of threads on the stud before lash was set.
Push rods are 9.146 long, I'm thinking we have the wrong studs, they stick up 1/4" above the rockers... Frown
Posted: 01/13/11
02:54 PM
I had that problem before the studs are to long you need deeper polylocks if your using polylocks ?
Posted: 01/13/11
03:05 PM
I was using a steel locking nut. Is there such a thing as a spacer that goes between the fulcrum and the nut??
Posted: 01/13/11
03:16 PM
You have to use polylocks with the studs your using .They will go down farther than stock nuts . What kind of rockers are you using ?
