Going to Cog Driven Blower Drive
wrp
User
Posted: 12/18/10 12:17 PM
We started rebuilding the belt system on my 2004 GTO. going to separate the blower drive from the accessory drive. Going back to a 6 rib serpentine for the accessories. Anyone need a slightly used 8 rib?
We were using the Innovator West overdriven dampener with the 8 rib. Upwards of 21 lbs of boost was wrecking the accessories. We've now gone to the ATi Dampener with the Procharger Cog set. We will adapt that to the Whipple.
A Bumblebee is considerably faster than a John Deere Tractor.
wrp
User
Posted: 01/26/11 10:14 PM
So here is the Blower pulley snout the cog fits on at the top
The initial goal was to see how high we could push a well built 408. We started wanting to go with a 91 mm Borg Warner Turbo then went through a Harrop HVT2300 and settled on the Whipple 4.0 Liter. The Lethal Performance Shelby with the 4.0 had a big impact, heck it was an inspiration.
Initially, we were just building a high horsepower car to stress Monster Clutch Prototypes. Beyond that we figured to wind up at the strip with an eye for the Texas Mile at some point. We'd like to turn in a respectable performance at the strip for the T56, with a Lenco T1200 and a built TH400 standing by. If you look at the build in readers rides you can see that the blower and the motor are actually only a portion of the build. The extensive drivetrain rework and suspension fabrication are nearly as important to our performance goals as the engine itself.
The large PD blower has presented some interesting challenges we did not anticipate but we are having a lot of fun figuring those things out. Thanks for your interest. One thing for sure, I am fairly confident no one is going to pull up beside me with a similar setup, but that is what it is all about isn't it?  .
wrp
User
Posted: 02/12/11 07:02 PM
Really happy with SNL visit today. Things moving forward. The upper cog drive and shaft are fabricated and ready to go. We have the tensioner and need to resolve mounting it. Right now waiting on belt and a couple of spacers. The best news is once everything is lined up we may not need to change the radiator.
wrp
User
Posted: 03/08/11 11:05 AM
Moroso Remote mount components began to arrive today
Posted: 03/08/11 04:54 PM
Looks like you may actually stuff all the worms back into the can eventually. Makes good sense what you're doing. Heres hoping none of it ends up filed under "broke chit", LOL. I'm thinking yer just mainly gonna go real fast and enjoy the fruits of your efforts, without so much wear and tear. Keep posting, man. More power to you!
wrp
User
Posted: 03/08/11 05:10 PM
IDK pull beside a guy in an exotic car and watch his jaw drop. That's fun  .
3836bbl
Posted: 03/14/11 03:59 PM
wrp hey how Ethyl doing, yep I'm over here now too, I figured I would check this forum out for a while being a Pontiac lover & all, I saw all of that stuff anything new. Man I'm good at spending other peoples money sometime. Se ya. 3836bbl/Budnicks
"Fill Your Library Before Your Fill Your Garage" 3836bbl alias Budnicks
wrp
User
Posted: 03/15/11 02:51 PM
Got the rest of the Moroso gear in today
3836bbl
Posted: 03/15/11 09:40 PM
wrp what's the trick looking tank going to be used for in the system. 3836bbl/Budnicks
wrp
User
Posted: 03/16/11 02:08 PM
We are moving the AWIC reservoir to the trunk. The front mounted one trapped a lot of header heat. We figure the extended hoses from front to back and the ability to get ice/dry ice in the filler neck of this one might improve the fun factor  .
3836bbl
Posted: 03/16/11 08:58 PM
wrp Interesting set up, keep us posted. 3836bbl/Budnicks
wrp
User
Posted: 03/26/11 06:12 PM
Complete Front End over haul underway as well, including bushings tie rod ends, ball joints. Also will incloude 90/10s and new front springs.
3836bbl
Posted: 04/04/11 04:03 PM
wrp is ETHYL ready to come out to play yet mine is laking in funding & a unmotivated owner, LOL. 3836bbl/Budnicks
wrp
User
Posted: 04/06/11 08:35 PM
New Valve Covers
wrp
User
Posted: 04/09/11 04:47 PM
Started on the remote water pump installation today. I am eliminating the tensioner on the passenger side and wonder if anyone might know of an aftermarket tensioner I can replace the fixed tensioner on the driver's side with?
Before
After, sorta
