Factory cam specs
Factory cam specs
pooshi pooshi
User | Posts: 170 | Joined: 01/10
Posted: 05/26/11
04:38 PM
Does anyone know what the cam specs (lift, duration, etc) were on a 1967 Pontiac 400 as it came out of the factory?
Posted: 05/26/11
05:12 PM
It depends on which cam it came with, there were several depending on the HP level. There was the 066, 067, 068 and 744. I have added a link to Wallace Racing's cam spec page and it lists full specs for almost all of Pontiac's cams. The hard part is figuring out what cam your engine would have come with. Often you would have two different cams for the same HP engine depending on whether it was a manual or automatic. For example the '69 HO 350 used the 067 cam for auto and the 068 cam for manual, to add even more fun to the mix they also used the 744 in early 69 350 HO's with manual but there were a couple of issues, one being the idle quality in cold weather with the bigger cam in the small motor and the other was the risk of high rpm failures due to the higher revving cam in the small engine which would still make power at rpm's higher than PMD wanted to see. See...fun huh? Grin
http://www.wallaceracing.com/camcode1.htm
Posted: 05/26/11
05:13 PM
What is the code on the front passenger side of the block.
pooshi pooshi
Posted: 05/26/11
05:19 PM
110544 WT is the code.
Posted: 05/26/11
06:04 PM
1967 400 335 HP WT M 10.75 067 670 1-4 7027063 Block Casting # 9786133
Int. Exh.
Application Stamp Dur. CL 1.50:1 1.65:1 O.L. Dur. CL1.50:1 1.65:1 Part #
1965-76 4bbl P 273 112 .407" .447" 54 289 113.407" .447" 9779067
pooshi pooshi
Posted: 05/26/11
06:21 PM
Thanks Pman, but I am having a hard time reading the info.
Intake valve lift is .407
Exhaust valve lift is .447
Duration is 273
Lobe seperation is 112
Is that correct?
Posted: 05/26/11
06:38 PM
No, .407 lift on both valves with 1.5 ratio rockers and .447 lift with 1.65 ratio rockers.
A 273 duration on intake and 289 on the exhaust.
pooshi pooshi
Posted: 05/26/11
07:01 PM
Thanks Pman, now I understand.
Posted: 05/26/11
07:02 PM
Your welcome anytime.
