74 SD 455 Engine for sale
rodder4hire rodder4hire
New User | Posts: 1 | Joined: 06/11
Posted: 06/11/11
06:01 PM
Have engine, block (485428), Heads (4x), Intake (495108), all brackets original but bad water pump, original fuel pump, fuel line, alternator, flexplate (for auto), all need to be rebuilt. Any Interest? Engine in NE CT.
Posted: 06/11/11
08:13 PM
Don't want to burst your bubble man, but that's not an SD455, it's a standard D-Port 455. That block number is the standard 215 or 250hp block and the heads are 114cc chambers with 2.11" intake and 1.66" exhaust valves, rocker studs can be either pressed in or screw-in depending on the production date of the heads, compression ratio will be around 8:1-8.2:1. Also if you look close, the intake manifold casting number probably ends in a 6 not an 8. It's not a boat anchor by any means, but it is not the legendary SD455. The price should reflect this information.
newbie455 newbie455
New User | Posts: 11 | Joined: 09/11
Posted: 09/12/11
05:46 AM
Question...I am a mopar guy but my buddy just picked up a '69 GTO with what appears to be a 1973 or 74 455SD motor in it - it's stuck presently. Any idea how much these are worth?? He is having it pulled & will be checking on all the casting/stamping #s plus looking around for how original/complete it is (ie: carb/intake/exhaust manifolds, etc).....he doesn't need it as he wants to do the GTO as close to original as possible (400-4)...I told him this motor might help him on his way to funding his resto. But I can't find any of these engines selling anywhere to give him an idea??
69redbird 69redbird
Enthusiast | Posts: 259 | Joined: 04/10
Posted: 09/12/11
07:08 AM
Rodder4hire;
The 455SD came with the following configs:
Year, Engine, HP, Engine Code, Trans, CR, Cam, Head Code, BBL, Carb No., Misc
1973, 455 SD, 290, XD, A, 8.0, 323, 16/485215, 1-4, 7043270, Block Casting # 490132
1973, 455 SD, 290, ZJ, M, 8.0, 323, 16/485215, 1-4, 7043273, Block Casting # 490132
1973, 455 SD, 310, non-prod. W8, M, 8.2, 323, 16/485216, 1-4, 7043273, Block Casting 490132
1973, 455 SD, 310 non-prod., Z8, M, 8.2, 323, 16/485216, 1-4, 7043273, Block Casting 490132
1973, 455 SD, 310 non-prod, X8, A, 8.2, 323, 16/485216, 1-4, 7043270, Block Casting 490132
1974, 455 SD, 290, W8, M, 8.4, 323, 16 /with stamped(6H), 1-4, 7044273, Block Casting # 490132
1974, 455 SD, 290, Y8, A, 8.4, 323, 16 /with stamped(6H), 1-4, 7044270, Block Casting # 490132
All the SDs were block casting #490132
I just bought almost the exact combination that you have. What are you wanting for it? If the block is still std. and unmolested and shipping is not astronomical I might be interested. I'm always looking for 455s. PM me a price and we'll go from there.
Newbie455;
Use the info above to check if it is a true 455SD
In its assumed current conditon (stuck) it is not worth much. Its true value lies with the car it was originally installed in. Then its worth something.
I know, it's not red
69redbird~~
How may I serve you?
Boiled, Deep Fried, or Flambe'?
newbie455 newbie455
Posted: 09/12/11
08:15 AM
What does "not much" mean Smile
The only thing I could see selling online were 455SD carbs on ePay with $1000 asking prices...that seemed high for a carb?
Again, I don't know if this motor is 100% original from carb to pan but want to give him a ball park on it's value assuming it is stock. I doubt we'll find the original car/owner that really needs it but somebody with a 455SD car must need one?
newbie455 newbie455
Posted: 09/12/11
08:15 AM
Oh and 69redbird - thanks for the info & very quick response!
69redbird 69redbird
Posted: 09/12/11
12:36 PM
Newbie455;
Not much means for someone just wanting a 455 for their ride - $200 to $1200 because the "SD" does not mean anything "extra" to them. Standard block 455s can be built to far exceed the factory capabilities of the stock SD.
The person that knows what it is and is selling it to someone that has a vehicle that came with a SD whether it is #s matching or not raises the stakes on the "value" of the engine. That could be as high as $2000 - $5000?? I'm no "expert" by any means - I've only been working on my own cars for 1.5 years now and still don't have a thimble full of knowledge on them. If it is real get a real collector to appraise it, it is rare.
The cars that have them that I've read about are all #s matching and totally original. They have been turned into trailer queens and the "fun" of driving them is gone because it is an investment and show car now. There are other guys I know that have one in a garage shrink wrapped for the "future" and it will in all likelyhood never see the light of day again. There are very few "originals" on the road as daily drivers or "I always drive it on weekends , rain or shine".
It is real hard to speculate on its value. If it is a real carb to pan / water pump to flex plate SD you would have about the only one out there for sale right now. Again, get a real collector or reputable apraisal firm to appraise it. There are plenty of people out there that will offer you pennies for what it is really worth counting on the fact that you don't know what it really is. It's the only way to know.
FYI - there were only 1296 of them made in 73 and 74 acording to PHS.
69redbird~~
newbie455 newbie455
Posted: 09/12/11
05:05 PM
Thanks again! This is great info....He's having the motor pulled & will be at his house this Wed for inspection on all the part #s, etc. I guess it sounds like he should get the appraisal if it is in fact a SD motor. I know he doesn't need it & wants to put the coin back into restoring the car -- which on it's own is pretty cool. '69 GTO convertible, red on white car! 400-4, auto, posi...Once he gets more info/appraisal and sells I will probably stick something back up here. I suppose reaching out to the SD car community is the best way of getting the $ for it. If you know anyone - let them know one might be for sale soon Smile Thanks!
69redbird 69redbird
Posted: 09/12/11
06:00 PM
Also, the 1296 number is firebird TA production numbers I don't know what the total production run of the 455 SD is and what all they were put in.
69redbird~~
1964Pontiac 1964Pontiac
New User | Posts: 18 | Joined: 09/11
Posted: 09/13/11
05:40 PM
Rodder4hire: I am interested. Do you have a price, pictures?
newbie455 newbie455
Posted: 09/28/11
08:14 AM
Ok....so he got the motor & it is NOT a 455SD motor  Frown
However, it IS a 1970 455HO "YC" from a GTO (4 bolt main)....
It's been sitting for over 20 years & is stuck, so it needs to be torn down & built.
No idea on std bore, etc...but it appears to be stock. He can pull other part #s, etc if anyone is interested. Offers?
Guru | Posts: 1257 | Joined: 11/09
Posted: 09/28/11
04:34 PM
The yc 70 GTO 455 ho engine is casting number 9799140 your engine is 485428 and is a 71 or newer 455 engine . If the heads are original your engine should be a 73 250 hp 455 .
Posted: 09/28/11
07:34 PM
Jack, Newbie455 isn't the same guy who started this thread, he's talking about an engine a friend of his has. We haven't seen any numbers on this motor yet, but it would be helpful. Funny, the guy who started the thread by trying to sell a standard 455 as a SD never came back after I pointed out that it was nothing special!
Posted: 09/28/11
07:44 PM
Lol. Very funny even when people were interested even if it wasn't SD. I just feel sorry for the person who ends up buying it, unknowingly.
Posted: 09/28/11
08:06 PM
Oh ? The 70 455 HO GTO engine is a good engine to have if the price is right and it is a yc 70 gto HO 455 engine ?
