400 in to a third gen firebird
knucklebustingarage knucklebustingarage
New User | Posts: 2 | Joined: 04/11
Posted: 04/27/11
02:20 PM
ok im havin some issue with this swap i cant find headers on the cheap and fitting it in the car wasnt the problem it was in the car once with factory manifolds i cant get the altanater below the hood line every thing else fits under the hood who or where can i get a pass side alt mount  im only 30 but i have fell in love with these cars and after i blew up that chevy 305 i had to build it the way pontiac should have my motor is from a 76 sj grand prix the car is a 86 firebird its caged but has a full guts everything works but the alt wont clear  also i want to turbo the motor and i have made it efi now using cadddy throttle body setup can i do that with out to much computer work? plez help i know all pontiac guy are a special breed of nuts but im hopeing that i can find a crazyer nut then me
69GTOby 69GTOby
Guru | Posts: 1114 | Joined: 02/09
Posted: 04/27/11
09:29 PM
That is quite a run on sentence  Grin .  Props for putting a 400 in there.  Try RA/HO Pontiac manifolds, there are reproductions available.  They fit well and flow well too.  Or try shorty headers.  Otherwise, you're stuck with logs or high dollar custom headers.
All I can say about the alt is try other brackets from other Pontiac engines from the yard.  You may have to make one, or just remove the hood  Cool
Can you lower the engine mounts for more clearance?
Addict | Posts: 5144 | Joined: 12/09
Posted: 04/28/11
10:53 AM
+1 GTOby
instg8ter instg8ter
Guru | Posts: 971 | Joined: 10/10
Posted: 04/28/11
07:19 PM
would probably not be too much work to fab a left hand mount, pontiac made all kinds of them for different years and applications though and the beauty is they will mount to most of the blocks and heads, maybe an old GM pick-up with the pontiac motor?? You could also try March performance for the brackets, they make all kinds of stuff or go serpentine. I like that you stuffed a REAL poncho motor in that F-body bet it will smoke the LS-1 crowd. post some pics.... Grin
and +1 for GTOby, headers and pontiac heads are a finicky mix (damn Siamese center ports)....i seriously spent 7 hrs. getting my headers and gaskets connected correctly (granted it was my first time in 25 years)in a car they were made to fit...buy the RA's, i will if i ever have to pull the engine again. Pain in the ass is not worth the extra few HP long pipes get you IMHO.
http://s1098.photobucket.com/albums/g372/instg8ter/1966%20Tempest/
"learning as i go, and going as i learn"
Brian
Torqued400 Torqued400
Posted: 04/28/11
07:33 PM
Hush your mouth G8ter, I got a gasket change coming up. Grin  Grin  Grin
"We build Excitement"
instg8ter instg8ter
Posted: 04/29/11
06:06 AM
man i feel for you T....LOL, get out the rubber sewing finger cups so you don't wear off your fingerprints trying to get the damn bolts started without stripping a thread.....mine are just growing back after two weeks, should robbed a bank while i had the chance to finance the rest of the build and a set of RA manifolds....Wink
Brian
69GTOby 69GTOby
Posted: 04/29/11
08:26 AM
Haahaha G8ter.
By the way, NAPA sells a really good exhaust sealing product.  When I first put my RA manifolds on using aluminum gaskets, they leaked everywhere.  I put a thick coating of the sealer on both sides of the same used gaskets, and they sealed perfectly, and still are!  High temp red RTV works as well.
montario22 montario22
New User | Posts: 1 | Joined: 02/14
Posted: 02/18/14
09:22 PM
I know I'm a few years late but what did you do for engine mounts?
