Performance combos for Pontiac 350
GC420 GC420
User | Posts: 56 | Joined: 06/11
Posted: 07/30/11
01:27 AM
I'm looking to do a relatively inexpensive build on my 350. I want to push close to 500HP if its possible but I'm thinkin i'm gonna need a 400. Current set up is fully stock w/ 2bbl carb and its a 73 Lemans 4dr. The idea is to set this car up so I can edge on it around the corners but to still have a strong drag car. Need to know what cam, lifters, rockers, valves/springs, bore etc would be best to achieve the amount of power I want. Also wanted to know whats the best gear ratio to run for me to be able to run this car to my preference. I'm thinking of running 3.42 gears. My driving style is high speed around the corners and a lot of slamming on the gas. My budget is anywhere from 600-1000 right now so were limited. I currently have a Quadrajet and Hooker headers to swap on. Outside of that I'm open for ideas..
Any suggestions?
Greg
"It's too close for missles Goose I'm switching to guns!"
Greg
Posted: 07/30/11
05:12 AM
Hmmmm, let's see.....you want 500hp out of a 350 or maybe 400 Pontiac and you want to work with a budget of $600-1000? On what planet? Seriously, this is not going to happen. When building any engine to produce that kind of power level, the first order of business is to fully rebuild the bottom end so you are starting with a solid, reliable base that isn't going to self-destruct after a pass or two. That means, at minumum you need to fully disassemble the engine and have it cleaned, inspected for flaws in the casting and machining, bore the cylinders with a torque plate installed to ensure the cylinders will be perfectly round and straight, check that the main bearing bores are aligned and straight. Resize the connecting rods and install good quality (ARP) rod bolts or replace them with aftermarket rods, install oversized pistons and rings, clean/inspect/machine the crankshaft and balance the rotating assembly. We haven't even got to the heads and cam yet and we've already blown your $1000 budget and maybe even doubled it or more. The heads required to make the power you want are not going to be the stock 73 350 2bbl heads. At minimum, you will need late 60's/early 70's small chamber/big valve heads which will likely require a full rebuild before they can be used and probably require porting to acheive your power goals. On the other hand you could step up to Edelbrock (or others) aluminum cylinder heads to really make the power. You will need a tall dual plane intake (Perf RPM) or single plane intake and at least a 750cfm carb, the Q-Jet will do if you know how to tune it. The headers will need to be 1 3/4" primaries, not 1 5/8" at this power level. I am currently building a 400 that I expect to produce between 450-470hp and 490 ft.lbs, I will have almost $6000 in it by the time it's done. If you would like to settle for around 300 real hp, we can come up with a combo for you that is more budget friendly but you will still be spending around $2000 or so to get a solid reliable performer.
As for the car itself, that's no lightweight and it's going to require a swap to some stiff springs and aftermarket sway bars and shocks, as well as rebuilding the steering and suspension with quality parts and poly bushings, good wide tires and rims to get it to handle in the twisties. I'm not trying to rain on your parade, just trying to put this all in perspective so you don't try to acheive an impossible goal on a limited budget. Nothing puts a damper on enthusiasm quicker than finding out half way through a build that you can't afford to finish what you started or that the finished porduct will be less than what you expected.
If you want to get realistic, we can talk about a header and exhuast system, 4bbl intake and carb swap, cam swap, some low buck sway bar and spring possibilties to get you out there and enjoying what you have, rather than having the car torn apart and abandoned for lack of funds or planning.
Posted: 07/30/11
06:52 AM
+1 Steve
Install your carb and headers and forget "close to 500 hp if its possible" from a 350 Pontiac for 600-1,000 bucks. A new intake will eat up a couple hundred, so you can mount the carb. Better put some dual exhaust too, another 300. Spend the other half of your budget on brakes, bearings, and steering, maybe a couple tires. Having the gear swap done by a pro and with fresh axle bearings costs about a thousand, so take your pick. Thats as close as you're gonna get for a grand and frankly the performance will still be unimpressive in a 73 Lemans sedan. Not wanting to dampen your enthusiasm here, but if you want a "strong drag car" that you can drift or get up on two wheels or whatever, start with a different vehicle.
big-g-67gto big-g-67gto
Guru | Posts: 905 | Joined: 07/10
Posted: 07/30/11
08:30 AM
sorry GC420.. Blush sometimes the end of the rainbow is futher than we think...
I got that Tin Indian GRIN!!
Torqued400 Torqued400
Posted: 07/30/11
08:47 AM
GC, Hey isn't this the motor that you replaced the head gaskets on and it wouldn't run?
  If you plan on rebuilding this motor, I would take it out of the car and haul it all up to your machine shop and have them check it all out. The machinist should be able to tell you if your block is any good and give you a price on machining it. Get all your machine work done and come on back here and tell us what he said and we can go from there. Wink  If you start throwing good parts after bad you're gonna be in a world of ..... Go talk to your machinist, he'll set you straight. -Rob
"We build Excitement"
Posted: 07/30/11
08:56 AM
+2 steve
69GTOby 69GTOby
Guru | Posts: 1113 | Joined: 02/09
Posted: 07/30/11
10:15 AM
Yea, lets be realistic.  Read my description for my mild 350.  I have about $1400 total in my engine, and it makes maybe 300 HP and 350 FT/LBS.
I also have several hundred in the brakes and suspension, and still need more yet.  Focus on the car as a whole.  500 HP will do nothing without a proper drivetrain to back it up.  Trans, rear axle, tires, strong suspension, brakes, etc...  Everything has to be not only sound, but sometimes even better than factory equipment for that much power.
GC420 GC420
Posted: 07/30/11
11:32 AM
Thanks for the advice guys. 1st I already knew my budget was tiny compared to what you pro builders are used to. I can get all of my machine work and most of the parts far below discount mainly I was looking for advice on which set up to run. I know also my 73 Lemans is heavier than the earlier models. Lets get past that. What I've gathered so far is that I need to find some 60's to 70's heads w/small chambers and bigger valves or go w/ some aluminum heads.
Next....my 350 is capable of pushing closer to 300HP within my budget range so I can settle for that now and build my 400 when the time comes.
So what combos can I use to achieve 300HP? And also if I switch the car to the Q Jet what work will need to be done on the heads if anything?
Greg
Posted: 07/30/11
12:25 PM
Post the casting numbers and date codes off your current heads, they may work. Your valve size may even work, but you'll want to go to screw-in rocker studs and adjustable locking rocker nuts if ugrading the cam. The spicier versions of the 350 were well over 300 HP stock, so you can't be that far behind. I bet you can get your new HP goal without much more than a cam change plus HEI, duals, and your headers and Q-Jet, if you are fair at tuning.
I'll stop right there, because I am not a "pro builder". This is a Pontiac 350, right?
Posted: 07/30/11
01:42 PM
GC, don't get me wrong, I'm no high dollar pro builder. I fix diesel trucks for a living and the build I mentioned above is my first hgih dollar build of my own. I have put some nice engines together for dirt track street stockers and built my own engines for 14 and 13 second street cars. The basics are always the most important aspect of any build. Sure you can bolt a set of heads/cam/intake and nitrous on a stock short block assembly and make some impressive power for a short time, many magazine articles have proven that. But if you want it to last you need to build it solid and look at the whole recipe including car weight, gears, tran, converter and so on or it will be a wasted effort in the long run.
GC420 GC420
Posted: 07/30/11
02:40 PM
to: Idrivejunk
Question above was if its a Pontiac 350?....answer is Yes its a Pontiac 350 not a SBC....that gonna be my next project for my 73 Cheyenne
Greg
69GTOby 69GTOby
Posted: 07/30/11
03:26 PM
That is what I did, built a mild 350 for temporary use while the 400 lurks under the work bench awaiting a substantial build, but not until the rest of the car, and my wallet are ready.
Maybe I am being modest saying 300 HP.  Perhaps 300 at the wheels.  I really don't know, as I have never dyno tested it.  It's a 350 +.060 producing 365ci.  Stock short block, mild Lunati Bracket Master II cam, #13 2.11/1.77 72cc heads,  9.2:1 CR, Edelbrock Performer intake, 750 vac sec Holley, HEI, Ram Air manifolds.
skyeking skyeking
User | Posts: 81 | Joined: 11/09
Posted: 07/31/11
05:21 PM
Cool  Laugh Hi there 420,
 You could get the existing heads throat ported and c'cd etc.
 The bracket Cam is good idea and it will give a flexible power band.
 As far as 500 hp Confused  Shocked  Blush  No Way Hoze'..
  Get about 300/330 hp and concentrate on these  questions.
 Brakes? //Handling and mostly Driver expertise which would account
 for at least 100/150 hp of what you LIKE to Have.
 Tune yourself up before spending a lot of cash,.  Believe me,It does work.
  All the best with the project... Laugh  Cool
skyeking
Daniel Austin Daniel Austin
New User | Posts: 3 | Joined: 02/14
Posted: 02/09/14
09:13 AM
I've got a 1970 lemans want more hp and torque it supposedly has a "383" stroker.  Unfortunately I have to rip my top end off to know for sure what's in it.  So lets just say its a 350 because bore and stroke is unknown.  Here's what I do know about the car for sure.  Im running:
3.36 68 chevelle rear end
boxed out now lower arms
68 chevelle upper rear frame tie ins
(Wheel hop solved)
Long tube hooker headers, dual 2.5" exhaust
Edelbrock performer rpm intake
holley 750 cfm 4bbl
e delbrock valve covers (serve no purpose just pretty to look at)
Mallory unilite dist, mallory coil, mallory 6al box
rebuilt th350
Unknown:
I know I have a cam in there it seems a little mild though
bore, stroke???
Im probably about 300-330 hp I feel I should be more probably runs about a 16 @ 95, chirps from 1st to second one time 2nd to third
Gonna port n polish, shave off .2 from head, replace seats, roller rockers, and do a 3 angle and put in screw in studs so I can run a stiffer cam. However should I not do this work to my stock 11's...should I or can I put 400 heads on a 350 with the larger valves ( will there be clearance issues?  What size cam should I rock?  I top out about 120 @6300 afraid to push it further even though I know it has it????  What upgrades can I do to get more without tearing my block down??
Thx Dan
Posted: 02/09/14
09:29 AM
Daniel, to start with we need to know are you dealing with a Pontiac 350 or a Chevy 50 small block? The 383 stroker is a popular combo for 350 Chevy (SBC) builds as you can buy Eagle stroker kits for under $800 thru Summit Racing. There is a 8 stroker available for Pontiac 350's but it costs a lot more and it probably isn't worth it, you'd be better off spending the money on Edelbrock heads than the stroker kit. Easiest way to tell the difference is to look at the spark plugs, do they point "up" at a roughly 45 degree angle or do they point straight out toward the frame? Straight out is a Chevy, up is a Pontiac. There are other 350's as well, Buick and Olds had there own as well. Let us know what you have and then we can discuss what will work for you.
