ignition timing nightmare!!
jeffb4 jeffb4
User | Posts: 57 | Joined: 06/09
Posted: 08/12/11
06:39 AM
Here is where my build is at for the 68 Firebird:
455 .030 over,
factory cut crank (my weak link)
balanced bottom end
ATI super damper
1971#96 d ports that are decked, polished, not ported, Ferrea stainless stock height valves, 3 angle valve job, Comp cams +.050 retainers, 10 degree locks
Ultradyne valve springs
Crane Cams Energizer 1.65 true roller rockers
ultradyne cam, .231-.239@.050, .538/.558 lift with 1.65's, degreed in at 107 degrees
Jegs noisy gear drive
holley street dominator
Holley blue fuel pump and external regulator set to 5 PSI
800 cfm quadrajet
Eagle forged h beam rods
TRW forged flat tops
10.1:1 compression ratio
1 7/8" to 3 1/2 "Hedman headers
new stock (I think piece of sh&&) distributor from Ebay
Accel 8.8MM wires
Autolite #85 plugs
TH350 with 2800 stall converter,
3.42 gears.
THE PROBLEM:
I cannot get the ignition timing right and running hot at idle (205 degrees). I have 14-16" of vacuum at idle, depending on how far I have my idle screw turned in to keep it running. I advanced the timing until I get the max vacum reading (in the travel available in this position it will NOT ping), retarded it 3 " of vacum, and I am at 25 degrees BTDC. At this point, the car will barely rev, is very sluggish. The closest I can get the initial timing with vac. advance plugged is about 18 degrees BTDC, any closer the car will not idle, idle goes too low, even with carb adj. screw turned way up, and stalls. I think there a problem with how my cam is degreed, although I degreed it.
With this combo, it has a mild cam. I built it more to be a solid combo than a really nasty street car. There should be no reason at all that I can't put a timing light on it, adjust my initial timing from 12-14 degrees BTDC right through 0 degrees without screwing with my idle adj. screw. What is wrong? Could the gear drive be machined wrong, but isn't that what degreeing the cam is for?
I tried to set the timing by ear until it sounded good, locked the dist. down, and took it for a ride. Before all this, last fall it had a stock 1973 455 with junk 4X heads. if you tapped the gas, then, it would burn the tires off. Now, it is very sluggish with no power and will not get out of its own way. I will address the running hot at idle problem once this problem is corrected, but with a brand new stock 3 row radiator, fan shroud, 7 blade clutch fan, stock water pump, there is no reason that this shouldn't run at 170-180 degrees at idle all day like when a little old lady bought a '71 Bonneville and drove it for 100,000 miles back in the early 70's. Ideas?
Posted: 08/12/11
02:02 PM
Jeff,
First things first, I would remove the number one plug and install a piston stop tool and verify the TDC position on the balancer matches the "0" on the timing tag. (Easy to make, just knock the porcelain center out of an old plug and run a 3/8" coarse thread tap through it and install a bolt through the center, voila, cheap piston stop). Roll the crankshaft all the way one way using a breaker bar and mark the balancer where it stops and then roll it back the other way and mark where it stops, the zero TDC mark should be half way between the two marks. If all is good it's time to tear into it and recheck the cam degree. I think you are already on the right track and I don't blame you for not wanting to tear it back apart.
Now on the other hand, I feel your CR is a bit too high for pump gas. Did anyone cc the heads after milling to see what they actually measure out to? How much did they mill off? Wallace racing lists a rule of thumb that says you lose roughly 5cc of chamber volume for every .025" milled off the heads, using their CR calculator I get 9.47:1 with a .030 over 455 using off-the-shelf TRW 4 notch flat-tops and zero deck height with the listed 96cc for the #96 heads but you need to shave almost .050" off to get to 10:1. Regardless you need at least 92-94 octane for the 9.5:1cr and 100 for 10:1 if you want to be safe for the long haul. I took the liberty of plugging the info you posted into my dyno sim program and posting it below. Disregard the yellow numbers in the red box as they are the numbers at 6250rpm as the test ends, the real peak numbers are highlighted in red below on the graph. Cool
Jeffb4455
skyeking skyeking
User | Posts: 81 | Joined: 11/09
Posted: 08/12/11
05:57 PM
Laugh   Hi there,
 If all else fails try this,
 I.D. of fuel line.
 5lbs fuel pressur seems a little light on.
 what distributor are you using,.
 4 core radiator would have been a better choice.
 Good luck with the project..
 The motor should run at 200* without being heat affected.
 Try changing the fuel or it's supplier.  Skyeking..
skyeking
Posted: 08/12/11
06:13 PM
+1 Steve.
skyeking skyeking
Posted: 08/13/11
09:28 PM
Laugh Hi there,
 I have been running 355s and ZZ1 for 10 years
 with 10/1 and our fuel supposedly has 6% sulphur
 in it..On your basis if any way genuine and
 comparable with the oil companies propaganda
 [ Assumed?] we are getting 93/94 rating which
  runs my ZZ4 very well from an advertised 98...
 Ideas Confused  Well theres mine buddy.. Cool
  Skyeking Tongue
skyeking
Posted: 08/14/11
04:39 AM
Icon Quoteskyeking:
Laugh Hi there,
  Skyeking Tongue
I'm not going to dispute what you say about running 10:1 on pump gas with a small block Chevy, but we are talking about a Pontiac V8 here which has a totally different combustion chamber design than the Chevy and tends to be more octane sensitive. Also I don't have complete cam timing specs available to me regarding the intake valve closing timing, which will drastically affect his dynamic compression ratio and therefore his octane requirements. I did try to find a cam card online for his cam but wasn't able to get that spec. So, to err on the side of caution, I recommend using the correct octane for the CR he has. Notice I also questioned the actual CR as to whether it was measured or assumed, if it was actually cc'd and calculated, then we know exactly what we are dealing with. If it was assumed, we could be a half point either way, better safe than sorry in my book. Another thing to remember is that many people don't have access to 93-94 octane let alone 98 and even then we have to take the oil companies word for it.
When somone asks me for advice I assume that they want their investment to remain safe and hand out my recommendations accordingly. If someone wants to try to run higher CR with lower octane and is willing to accept the possibility of internal damage due to audible or inaudible (remember the human ear cannot hear certain frequencies and that gets worse the older we get and more time we spend with loud exhaust and impact wrenches!) detonation, then that's their gamble but I will not advise someone to try it unless they know what they are doing.
But the original question didn't actually concern detonation did it? It was mentioned as not being heard, but the problem is the engine won't run at normal timing settings and has much less power than expected, so the first order of business is figuring out why and that's why I recommend rechecking TDC and cam timing. I mentioned the octane issue for when he gets it to run correctly. If there was no issue in the timing areas it would run fine at idle and very light loads, even on 87 octane, then we could assume that octane, CR and fuel pressure were a factor in detonation and performance. But first it needs to run right.  Grin
Posted: 08/14/11
05:44 AM
Pontiac engines should never be compared to a chevy engine totally different.
Also the ZZ crate engines have aluminum heads as well.
jeffb4 jeffb4
Posted: 08/15/11
04:00 AM
Hello all, thanks for all the input. Steve- I had these milled years ago, not sure how much was milled off. But I cc'd them myself (the best that I can) with a piece of plexiglass and grease as a seal over each combustion chamber with valves installed and closed. I used the food coloring and alcohol trick, and got an average of 90-92 cc's per combustion chamber, and 6-8 cc's per piston (for the 4 valve reliefs) I think I found my problem, I will post the results once I finish it, I ran out of time yesterday. Thanks again guys, Jeff
1BADPONCHO 1BADPONCHO
New User | Posts: 4 | Joined: 08/11
Posted: 08/18/11
05:29 PM
I have a question - if you all dont mind. I have a 400 and i am having issues timing it. It is ran primarily for racing only. It has 11:1 CR, fireball cam, holley 850 and a torkerII intake. The heads are #62 and are fully ported. I also have 1.65 roller rockers. So heres my issue now that you have a little info on my setup. I run my distributor with the vacuum advance removed and a lockout plate installed. I have light weight springs as well. I am told i should set my initial timing to 12 btdc. Just for clarification is this done prior to starting the motor and doing it by hand? Or do i set to 0 by hand first. Start and then advance it to the 12 mark on teeth? It has been A LONG time since i have messed with distributors and HEI so please dont think i am dumb..lol... Now, i have researched many sites and i see that stock, daily driven ponchos should be set at 12 degrees initial timing, where might i want to be?
So here is what i did step by step, let me know if i am missing something as far as initial timing goes.
1 - pulled #1 plug and DS valve cover.
2 - rotated engine by hand watching valve movement and ensuring both were in closed position.
3 - looked at balancer and noted it was at 0/TDC
4 - rotated engine by hand further till TDC on balancer was lined up with the 12 on the 12 BTDC.
5 - pulled cap to verify rotor placement. It was in fact on 1.
6 - reassembled
7 - started up instantly/let idle at about 750 till warm (150 degrees)
8 - hit balancer with non adjustable timing light, noted it was reading 4 degrees ATDC.
9 - this is where i got confused, and decided it was time to ask for assistance.
So did i do something wrong as far as setting initial timing?  Some clear and detailed input would be greatley appreciated. Just want to say again that i have the distributor locked out. Thanks for any input that can break this down for me barney style.
Posted: 08/18/11
05:56 PM
Actually you did little wrong.,. except step 3 where you arrived at TDC going clockwise, then step 4 you backed up (counter clockwise) to get 12 degrees, right.,. this is wrong, you can't do that and expect accurate timing.,. you need to go in the direction of engine rotation.,. clockwise as seen from the front of engine.
You have slop in your timing chain and by backing up this slop gave you the 12*
when you fired the engine, this slack was taken up going clockwise.,. hence the mystery explained, from 12* BTDC to 4* ATDC.
Get a new timing set and try that all over again.
Posted: 08/18/11
06:11 PM
I have a double roller installed. Do those normally get slack after a few years? And yes i did what you explained. Could i just bring it all the way back around and stop at 12 btdc and see where i am at at idle? Also, at idle would a chain with slop cause the timing to wander? I ask because mine sits still. Thanks for the info. Much appreciated.
Posted: 08/18/11
06:25 PM
Timing chains can stretch after a few months of running the engine hard.,. it also depends on the valve spring load that the timing set is up against with each engine revolution.,. high RPM's kill chains and is one reason racers prefer gear drives.
Do all your adjustments going clockwise.
To see if your chain is stretched or not.,. remove the distributor cap and rock (rotate) the engine back and forth until you see the rotor move.,. this indicates chain stretch PDQ.
Posted: 08/18/11
06:27 PM
Will do, thanks.
Posted: 08/18/11
06:29 PM
You welcome.,. good luck.
jeffb4 jeffb4
Posted: 08/20/11
06:22 AM
Well, I thought I found the problem- pulled the timing cover, got top dead center on compression (finger in #1 hole, clicked the key, got lots of psi coming out of #1 cylinder, balancer was really close to zero. Hand turned engine until zero was perfect. My cam and crank gears were both at 12:00 Problem found? Yes, all excited, put in a double roller chain, degreed it, put it in at 12 o clock on crank, 6 o clock on cam gear. Got it back together, still can't set initial timing, can get it closer, approx. 16-18 btdc, but then again, will barely idle, not responsive at all, but when I reconnect the vac. advance, the idle comes up like it should and sounds decent. I checked timing on #1 and #6 cylinders, exactly the same, should they be? Has anyone ever heard of a timing light going bad? Out of ideas. next I will be putting the points distributer back in, or piece together another HEI
