Closed Combustion Chamber vs Open Chamber
FB338 FB338
New User | Posts: 7 | Joined: 12/11
Posted: 12/31/11
04:03 PM
I'm new to your forum and have a few questions. I'm in the middle of a rebuild, stroking a 400 block to 461ci. I have a set of iron heads #17 that I was running on a 350 that Bulter Perf. ported/ added bigger intake 2.11 /exhaust 1.77 valves. They are flowing ~242cfm @ 0.500. I came across a set of #670's Closed combustion, Question, whats the difference in performance with the open chambers (#17's ) vs the 670's Closed, if ported? Would it be worth any gain to work the 670's?
Posted: 12/31/11
04:20 PM
I would stick with the open chamber heads as the closed chamber larger valve heads have valve shrouding issues.
I would also watch how much CR you run if using pump gas.
FB338 FB338
Posted: 12/31/11
05:26 PM
Thanks Pman,
I 'm going with 9.5:1 CR, using Ross custom piston ~25cc dish with the heads at ~73cc should give me 9.5:1... I hope.
Posted: 12/31/11
06:11 PM
Your welcome anything else just ask.
