Finally got the 455 running in my bird
69redbird 69redbird
Enthusiast | Posts: 259 | Joined: 04/10
Posted: 07/31/12
10:43 AM
It is alive!
(with A/C too!)
Special thanks to MB68BIRD
1972 4 bolt block #485428
Block decked and squared to +/- 0.001
original crank .010/.010
Tomahawk A-beam rods 4340 steel with ARP 8740 bolt. Bronze bushing
Icon IC-888 pistons +0.030
4X-3H heads SD ported to 250CFM 98.5cc (~9.36:1 CR)
COMP CAMS Hyd. roller 230/236 @ 0.050 112LSA 108ICL .565/.570 lift
PRW 1.52 roller rockers
Eddy performer RPM
Holley 750cfm vac sec.
MSD 6AL-2
MSD 8563 dist. 10deg. initial, 25 deg. limit, all in @ 2800RPM
Doug's 1.75" long tube /3" collectors
Trans 200-4R
Ford 9" w/3.55:1 TracLoc
255/45/17 26.1" dia.
3,150LBS with me in it & 1/2 tank of gas
Chassis dyno run yesterday @ 103 degrees ambient, cheap CircleK 91 octane gas - no pings
Dashed=TQ, Solid=HP
Bluebird Dyno 20120730 1
Dashed=AF ratio, Solid=HP
Bluebird Dyno 20120730 2
Cool
I know, it's not red
69redbird~~
How may I serve you?
Boiled, Deep Fried, or Flambe'?
Formula73 Formula73
User | Posts: 51 | Joined: 07/12
Posted: 07/31/12
11:19 AM
Sounds sweet!
'73 Formula 400
'74 Trans Am 455
mb68bird mb68bird
Posted: 07/31/12
12:43 PM
More to come
whos's first ***
69redbird 69redbird
Posted: 01/30/13
08:32 PM
New engine setup
Cool
(Items that are BOLD and UNDERLINED are the changes)
LUNATI VOODOO 40510511 SOLID ROLLERS
Advertised Duration (Int/Exh): 278/285
Duration @ .050 (Int/Exh): 242/249
Gross Valve Lift (Int/Exh): .556/.556
LSA/ICL: 112/106
Valve Lash (Int/Exh): .015/.015
Eddy performer RPM
Professional Products PowerJection III TBI
MSD 6AL-2
MSD 8563 dist. 18deg. initial, 18 deg. limit, all in @ 2500RPM
Trans 200-4R
3,300LBS with me in it & 1/2 tank of gas
AND.....(at the wheels)
20130130 01 455 Voodoo Zps0af2cb16
20130130 02 455 Voodoo Zpsaf6d5f03
Grin  Grin
Not done tuning but it's a hoot!
Cool
Can't imagine what the bottle's going to do -  Wink
69redbird~~
fastoneefi fastoneefi
Enthusiast | Posts: 347 | Joined: 01/10
Posted: 02/01/13
07:24 AM
Nice numbers!
I guess you're probably between a rock and a hard place huh?. I'll bet you want to keep the compression ratio reasonable with nitrous but it's obviously a bit low for that solid roller and aluminum heads. Wink
Which version did you go with on the PJIII, the 750 or 1000?
Mark
Engine builder, located in Central Florida
69redbird 69redbird
Posted: 02/01/13
10:51 AM
The PJIII has only one option for the throttle body - 910CFM #70026 (though they call it a 750)
The existing heads are cast iron (4X-3H) not aluminum.
SD Performance CNC ported to 250CFM @ 0.500
98.5cc with 2.11/1.77 valves & 7/16 studs
9.36:1 CR
I set it up for 91 octane pump gas with an eye for the future.
The future would be Eddy 87cc aluminum heads ported to 315 or so.
That would yield a CR of 10.31:1 still good for 91 octane.
The bottle is just for additional driver adrenaline injection Cool
69redbird~~
Posted: 02/01/13
04:33 PM
Man what a boot in the britches, eh? Very nice, it must be a monster. Of course the bottle is like getting both boots ...
Formulajim Formulajim
Enthusiast | Posts: 379 | Joined: 02/09
Posted: 02/04/13
09:28 PM
How do you keep the tires from spinning! Love that torque.
Drive it before your dead!
