400 stroker
chevylt4
Posted: 01/15/13 12:07 PM
how many cube with a 4.25 stroke crank and big block chevy 6.135 rod in a 400 block with 0.030 overbore...tank you...
Moderator
Posted: 01/15/13 03:35 PM
460.1 cubes
chevylt4
Posted: 01/17/13 10:32 AM
the piston forged flat top that i alerady can you install it be with this combo...and thank you for your info....
Posted: 01/17/13 11:02 AM
Regular 400 or 455 pistons won't work, you need ones designed with the correct wrist pin height for that stroke and rod combination. Best bet is to buy a complete balanced rotoating assembly from Butler's, Kaufmann's or Eagle. Steve
chevylt4
Posted: 01/17/13 05:17 PM
it is because I already the eagle 4.210 crank with rod to stroke eagle 6.135 in their box and I would like to install in my 400 block and what kind of piston would be best to put with this combination...
Posted: 04/03/13 06:47 PM
I think you may get better answers if you provide more information. What exactly are you going for? What exactly do you have for pistons already? Compression height? Has the block had any machine work done? Do you care about quench?
This hot rodding **** is harder than I thought it would be!
Opontee
Guru
Posted: 04/04/13 12:02 PM
Bore x bore x stroke x # of cylinders x .7854= ***
Your going to have to get a special piston made. Cost prohibited. Stock Pontiac rod is 6.625 long. I have an Ohio Crankshaft 4.25 stroke, 6.8" rod (2.2 pin dia) and .035 over bore 455. And you need to remember that 400 has a 3" main and 455 has a 3.25" main. BBC also has a 3" main, but the cranks are NOT interchangeable between and Chevy and Pontiac.
  Anna Mae quit.
Opontee
Guru
Posted: 04/04/13 12:04 PM
double post
  Anna Mae quit.
