1st Gen Camaro rear into a 1st Gen Firebird?? - High Performance Pontiac Forums at High Performance Pontiac Magazine High Performance Pontiac
GMW-68Bird GMW-68Bird
New User | Posts: 7 | Joined: 01/13
Posted: 02/01/13
06:00 PM
I have a 68 Firebird with the correct 8.2 BOP posi rear. My buddy has a 68 Camaro 10 boltl rear with 3:90 gears that he no longer needs as he is swapping out for a 12 bolt rear.
My question is what's involved if I swap rears? Is this a direct swap or are there any hidden changes? Has anyone done this swap?
Addict | Posts: 3191 | Joined: 01/07
Posted: 02/01/13
06:48 PM
Should be a direct swap. Do both cars have multi-leaf springs? You may need to fab brackets to the Camaro rearend if your Firebird has the torque arms. Check to see if the yoke for the rear u-joint is compatible. Otherwise it should bolt-in.
Posted: 02/01/13
07:23 PM
Yes both cars have multi leaf springs. I don't have torque arms on my Firebird. I figured the rears would be a direct fit, I was mostly concerned with the driveshaft fitting. I'm not interested in this swap if I have to customize my driveshaft or find a new one.
pepsi68 pepsi68
New User | Posts: 1 | Joined: 02/13
Posted: 02/01/13
09:28 PM
10 Bolt  direct swap.
12 Bolt is also a direct swap.
Formulajim Formulajim
Enthusiast | Posts: 380 | Joined: 02/09
Posted: 02/04/13
09:05 PM
They make u-joints that step, so anything should work.
Drive it before your dead!
Enthusiast | Posts: 647 | Joined: 07/11
Posted: 02/04/13
11:09 PM
firebird rear end will have bolt in axles camaro will be c-clip style and the firebird rear may be 1" wider. i was surprised to find this out. the camaro rear end i have is a 69 and firebird is a 68.
69 GRAND PRIX 406/5SPD
