LS technology for a pontiac engine
Posted: 01/11/13 01:46 AM
With all the advantages of the LS engine why is its technology not being adapted to the Pontiac engine. I would like to keep my Pontiac engine in my firebird but I also want an engine that is powerful and efficient. Wouldn't it make sense for heads to be designed to bolt on a LS intake as well. It would give us great head flow and fuel injection that would fit under any hood. I know edelbrock now offers heads with new chamber design but they flow less than the round port performers already on my engine. A stock set of ls heads flow around 350 cfm. This compined with the chamber design is why these engines are so powerful and efficient. A timing cover with a crank sensor would be pretty easy. A reluctor ring on the timing gear. A valley pan with knock sensors and one could use all the electronics that run the LS on our Pontiac engine. Yes the heads would require custom headers but considering the poor fitting P.I.T.A. choices we have now what would the downside be. If we are putting aftermarket heads on our engines why not design them to take advantage of new technology and the parts already available for a great design.
Posted: 01/11/13 09:13 AM
It all adds up to cubic dollars for what would amount to a very small market segment. The vast majority of classic car enthusiasts want classic cars for the simplicity of their design and ease of repair. Those looking for the high tech route usually have no qualms with butchering a classic to get modern technology under the hood. Don't get me wrong, there are some cool advantages to going high tech, but for many it takes the charm out of owning an older car. Personally, I will forego even poly bushings in favor of new OEM style rubber because I want my car to ride like it did when it was new not like a new late-model car, just my opinion. Steve
mb68bird
Posted: 01/11/13 09:41 AM
With some of the advanced aftermarket Pontiac heads already out there you are going to spend 12k by the time you get to bolt them on a block. I don't think the vast majority of Pontiac owners can fork over that kind of cash. Plenty of power can be made with factory Pontiac parts for a street car and you can always put EFI on top.
fastoneefi
Posted: 01/11/13 02:23 PM
New, efficient heads, an EFI converted dual plane, along with a crank triggered multiport EFI running in sequential, will give you the ultimate while still retaining the original Pontiac motor. I have a stock block EFI'd 350 Olds. The difference between that and when it had a carb on it is night and day. But as mentioned, $$$ is the deciding factor alot of times. But for the record, I wouldn't change a thing on it at this point, again night and day difference.
Mark Engine builder, located in Central Florida
Posted: 01/11/13 06:10 PM
It has crossed my mind on several occasions that this makes sense, if only to a guy who can make things and has the right items. Using a modified computer, fabbed intake, a handful of make-your-own adapters and modified poncho parts, I'd like to think that a properly educated individual could do this using stock or aftermarket Pontiac heads, exhaust, and an existing OEM induction / ignition setup from a similarly sized V8. The point of using Chevy LS salvage parts rather than glittery aftermarket ones would be to keep the dollars down and force ingenuity. I think it might catch on if someone worked it out in kit form and knocked a thousand off the other current EFI market's Pontiac offerings.
Posted: 01/18/13 05:33 PM
Yes I agree there are some great aftermarket multiport fuel injection units on the market. I don't agree that there is efficient aftermarket heads available. If you are designing a new head why not use proven technology. How many old Pontiac's are sitting in garages and not being driven just because we can't find good fuel, at a reasonable price, or because it only gets 12 MPG. Some time ago I read some info about edelbrock pro port heads and got excited because they seemed to address some of the design issues but since have not seen anything on finished head performance. I want to build a powerful and efficient engine. If I have to build one that is at least 461 cubic inches to be powerful by today's standards its not going to be efficient. A 406 with a properly designed combustion chambers, intake and exhaust runners would be a lot more appealing. If we have to build a low compression engine to run on today's fuel there is no way it will be efficient. My current engine is a 400 bored. 030 4 inch stroke, edelbrock performer heads with a hydraulic roller( unknown specs) torker intake 750 Holley dp. It runs okay but I do not like the cam. Only pulls to 5000 rpm. Even with this mild cam and low compression this engine is a pig. My right foot is some what to blame
Posted: 01/18/13 06:03 PM
Look at the current LS engines being offered by companies like Mast Motorsports these engines are so powerful and efficient because of the head and intake design. A Pontiac short block would make the same power and be as efficient with this technology applied to it.
fastoneefi
Posted: 01/19/13 08:04 PM
1973formula: Yes I agree there are some great aftermarket multiport fuel injection units on the market. I don't agree that there is efficient aftermarket heads available. If you are designing a new head why not use proven technology. How many old Pontiac's are sitting in garages and not being driven just because we can't find good fuel, at a reasonable price, or because it only gets 12 MPG. Some time ago I read some info about edelbrock pro port heads and got excited because they seemed to address some of the design issues but since have not seen anything on finished head performance. I want to build a powerful and efficient engine. If I have to build one that is at least 461 cubic inches to be powerful by today's standards its not going to be efficient. A 406 with a properly designed combustion chambers, intake and exhaust runners would be a lot more appealing. If we have to build a low compression engine to run on today's fuel there is no way it will be efficient. My current engine is a 400 bored. 030 4 inch stroke, edelbrock performer heads with a hydraulic roller( unknown specs) torker intake 750 Holley dp. It runs okay but I do not like the cam. Only pulls to 5000 rpm. Even with this mild cam and low compression this engine is a pig. My right foot is some what to blame
With all due respect I hate to say it but with low compression and apparently a mild cam, that Torker was a poor choice. That may be part of your performance issues.
All you'd have to do is change the intake, Professional Products makes a nice EFI ready dual plane, the cam if you wanted, then add EFI. Remember the better systems allow you control spark, with the ability to add it when cold and gradually take it out as the engine heats up. That's the best of all worlds and really aids in overall efficiency. And with the lower compression you could probalby run 87 octane with little or no issues. Plus you can run an EFI'd motor leaner than you can a carbed one because of the lack of inherent fuel distribution issues, further enhancing it's efficiency
If you decide to go that way give me a shout, I can help.
Posted: 01/21/13 10:40 PM
Thanks Mark. I agree about the intake choice being wrong. Before I bought this engine from a friend of mine I suggested an edelbrock performer rpm to him. Next time I went up to his house he had a torker 2 intake on it. The engine and transmission are now sitting on my garage floor. Before it goes back in I will be makng some changes. Before I sold this car 20 years ago it had a 400 with small chamber big valve heads. With a 305h comp cam torker intake 750 Holley. That set up ran really strong but was a pain in the @SS at low speeds. Four speed 3.55 gears. But it wasn't a daily driver and I loved the way it pulled to 6800 rpm. But that was when you could get 94 octane at the pump. So the trick will be trying to get something close performance wise to run on what is considered high octane now. Thinking milling heads, solid cam and fuel injection. I still wish we had better head choices for street engines.
Posted: 01/22/13 12:00 AM
Sorry guys this obviously is not working typing on my phone. I can't see what I am posting. I was wrong about the stock LS head flow but not by much. I was thinking of the ones available through GMPP. Does anyone have any info on edelbrocks pro port heads finished to run on a smaller cubic inch street engine? The reason I am interested in these heads is not only the flow potential but also because the combustion chamber can be shaped to work with today's pump gas so the potential is there to build a engine with 10.5:1 or higher compression that will not detonate. I will probably have to have a custom intake made so I can run multiport fuel injection that will fit under my hood since the intake ports are raised. For now I am going to fix the issues with my current set up so I can drive it. My future plans are to build an efficient and powerful smaller cubic inch engine so I will enjoy it even more. Just curious how many Pontiac enthusiasts would radically change the look of their engines if it meant significant gains in mileage?
