Comp Cam 268H
Comp Cam 268H
bradshdj bradshdj
New User | Posts: 45 | Joined: 02/13
Posted: 04/23/13
08:05 AM
Just thought I would leave some info on the Comp Cam 268H after recently installing it into a WT Block 400 with 4X heads, 4 speed and 3.42 geared 74 TA.
The engine runs great.  It has a lope but nothing that jumps out at ya.  My concern for this cam was the vacume for the brakes.  Brakes works great with no problem.  With this upgrade in Cam, we installed matching valve springs, retainers & seals.  Using 1.52 Comp Cam Roller tip rockers.  Also changed Timing set with a Crane billet with pre-stretched Chain, Billet Pulleys, Aluminum water pump and timing cover.
The engine definitely accelerates better with the tighter LSA.  From 114 - 110 I couldn't believe how much quicker the motor responds.  Definitely got increase in Torque and HP.  Very very pleased with the cam.  Today taking the car out for a clean up and then take some pictures.  Will let you know when the intake carb and distributor are finished.  Car looks and responds great.
Very happy with the help I received from Barnett and Pontiac Man.  thank you very much for your recommendations and knowledge you shared with me.
Posted: 04/23/13
08:49 AM
I as well as others I’m guessing love to hear back on projects to hear how well they do or don’t perform. From what I have seen few do that. I saw that post before I joined.
xxxxx
Great to hear, I've run that and the xe comps myself. It’s funny there seems to be a small difference between this and the xe268h on paper vs the xe274h but I’ve run them both and I’m tellin you it’s very noticeable.
xxxxx
Yeah, in general the tighter lsa seems to pack more punch in a narrower range. You would notice even more difference had you used an xe one but it’s not quite as well mannered as the one you used.
You are the one that bought that cam in the first place years ago if fading memory serves me right so you made a good choice in the first place.
xxxxx
Look forward to photos
xxxxx
bradshdj bradshdj
Posted: 05/19/13
06:04 AM
My TA is on the Readers Rides.  It is the White 74 TA
goatwool goatwool
Enthusiast | Posts: 384 | Joined: 07/10
Posted: 05/19/13
06:12 AM
That is the same combo I used in my 400 GTO. I really like the cam as well.  Nice slight lope but still fair vacuum and idle.  I'm very pleased with the combo.
Posted: 05/19/13
06:28 AM
Cool, that and the XE268H-XE274H are very popular cams. I'll check out the photos. Always fun to hear back how something work once one gets the part installed etc.
Just curious what carb and intake are you running and what are you changing to?
goatwool goatwool
Posted: 05/19/13
06:43 AM
I'm runnning a Qjet.  I sent it off to Cliff's High Performance for a full rebuild - I did a standard rebuild and it was still lacking - but when I got it back from Cliff's - wow!  Come to find out my Qjet is a superduty 850cfm - sweet!  Oh, and an Edelbrock Performer.
bradshdj bradshdj
Posted: 05/29/13
12:07 AM
My Intake I am putting on in a couple of months is a Edelbrock Performer RPM.  The Carb is going to be a Holley 750 HP.  Since I cant run the RPM manifold with the shaker being at a standard height, I have purchased an old Shaker that needs to be restored first.  To relocate the Shaker I am having to also purchase a relocating kit from Blocker in Arkansas.  When the second shaker is restored I will get the rest of the components and do the swap out all at once.
Posted: 05/29/13
02:44 AM
They make shaker drop bases for 76 thru 79 firebirds especially to use an rpm intake on them at jbp.com
bradshdj bradshdj
Posted: 01/14/14
03:30 AM
Just an update.  I purchased a Blocker Shaker Kit from an outfit in Arkansas and it fit like a glove and keepts the Shaker at the correct factory height even though I am using the Edelbrock RPM highrise.
Great choice, looks good and simplet to install
Posted: 01/14/14
07:26 PM
Hi;
Thanks for the update, glad it worked, helpful info for others considering doing this.
