69 GTO Cluctch Rod
jtwoods4
Posted: 02/11/13 09:00 AM
Hey Guys,
I have the 2 piece Z-Bar setup for my 69 GTO. The clutch rod that attaches to the lower part of the Z-bar has a "slit" in the end where it connects. This slit slides over the end of the z-bar and then a bolt goes through the rod and zbar. Does anyone know where to order this clutch rod with a slit in the end?
See picture:
Posted: 02/11/13 06:16 PM
There is no small bolt or slit on a 69 GTO clutch rod set up ? This is a 69 GTO clutch rod it should also have a nut on it ! This is the heavy duty one that I have on mine you can get it from Ames !
My71
Guru
Posted: 02/11/13 06:29 PM
That looks like an aftermarket linkage part..
