rear axle id/ need help figuring what gears to buy
Posted: 03/03/13 01:00 PM
hi everyone, trying to id what rear axle i have, looked this up on the internet, but makes no sense- the rear that is in the car has axles that are retained by the wheel bearings, ring gear bolts are 11/16" socket rh threads, car is a '68 gto, but i'm not sure if rear is original, car has 3.23 gears currently, ring seems to measure 8.2". apparently i can have 2 different 10 bolts that are 8.2", one is corporate and one is bop and the gears are different between the 2. here is a link http://www.crankshaftcoalition.com/wiki/Rearend_identification
Posted: 03/03/13 01:02 PM
Posted: 03/03/13 01:03 PM
Check out this other thread, dealling with the same issue and lots of good info: http://http://forums.highperformancepontiac.com/70/9375373/drivetrain-upgrade/wishing-to-change-10-bolt-69-pontiac-gto-rearend-g/
Posted: 03/03/13 01:04 PM
Looks like you have the BOP 8.2", same as my 1970 Tempest. Steve
Posted: 03/03/13 01:06 PM
link didn't work!! incidentally, i'd like to put 3.73 gears in it, am i wasting my time and should find a 10 bolt out of a chevelle? this rear has a brand new powertrax unit in it. i guess a better way to put it, is this a good rear axle from a performance standpoint? car is a stick, i'll probably run drag radials and i'm wondering if this is a good way for me to go. i know alot of people have run fast w/ the gm 10 bolt 8.5", and i'm curious if this rear is as good.
Posted: 03/03/13 03:26 PM
I'm going to find out the hard way I guess, i just invested in a new Auburn posi and Yukon 3.55 gears for mine! Steve
My71
Guru
Posted: 03/03/13 03:37 PM
+1 Steve. That looks like the BOP 8.2".. From a performance standpoint, I'd look for an 8.5" or even a 12 bolt.
Moderator
Posted: 03/03/13 03:45 PM
actmobmar: link didn't work!! incidentally, i'd like to put 3.73 gears in it, am i wasting my time and should find a 10 bolt out of a chevelle? this rear has a brand new powertrax unit in it. i guess a better way to put it, is this a good rear axle from a performance standpoint? car is a stick, i'll probably run drag radials and i'm wondering if this is a good way for me to go. i know alot of people have run fast w/ the gm 10 bolt 8.5", and i'm curious if this rear is as good.
I fixed the link, so now it works.,. The 8.5 is only 3/8" smaller than the 12 bolt. I'd go with the 8.5, if it's available to you.
Posted: 03/03/13 05:16 PM
i'd have to find one, but it seems like there out there. its a shame because this already has a powertrax in it, along w/ new brakes
76Tranz
User
Posted: 03/03/13 08:56 PM
Just my 2 cents, but I would buy the 3:73 gears and put them in with the good stuff you already have and drive the (fire) out of it! Unless you're pushing 600 hp out the back door, I wouldn't worry about it. You will probably have years of enjoyment out of it with no problems. Drive it 'till it dies, then find an 8.5!
Posted: 03/05/13 09:00 AM
I just read that there are different carriers the car had 3.23 gears do i also have to change the carrier to go to 3.73?
Posted: 03/05/13 10:36 AM
Yes! The carrier changes when you go from 3.23 to 3.36.
Posted: 03/09/13 05:44 AM
i ended up buying a 12 bolt out of a chevelle, 2.73 posi, so i'll have to do a gear change, if memory serves correct they make a 3.73 gearset to go on the 2 series carrier
