Ethyl's Twins - Precision 6266 on a 408
wrp wrp
Enthusiast | Posts: 318 | Joined: 12/10
Posted: 08/22/13
09:45 PM
I appreciate you guys and gals following us on the Whipple build. We had a lot of fun with the Whipple and learned a lot of things. In all, over 750,000 views were logged against the Whipple build through several of the top sites. For five years now we have dealt with the Whipple and watched our build go from a one of a kind to seeing the COPO Camaro 4.0 Liter Upgrade using much of the same things we discovered, though to a much better result. I'd have to declare the Whipple a success. We decided to go a different direction after many hours of discussions with Mike@Whipple and Brent@CBM. Both of those guys helped us many ways over the years to overcome problems and come to solutions. The result is if/when I buy a Camaro, the 4.0 liter Whipple, 170mm TB and Crusher intake will be my choice.
For now, we wanted to go a different route. SNL Performance has long been heavily engaged in Turbocharged applications and we really wanted to apply the same level of effort to a Twin Turbo Setup with as much passion as we put the Whipple package together. Steve Addison of SNL had studied the twin turbo applications found in some of the rear mount technology and the APS kits. Over the years we have helped customers with Twin Turbos replace kit designs with larger turbos, we've ported Turbos and accomplished a dozen other tweaks. In many cases constraints in the customer goals limited the outcomes. On this build Steve made a special effort to understand my goals and then set out to have my fabrication done in a manner that is consistently high in quality and easily repeatable.
We chose to fabricate the installation so that it fit the existing 2004 GTO (Ethyl). We did not want to spend a large amount of time moving brake lines and electrical fuze boxes. If you are looking for exotic and innovative ways to tuck the ABS, we were not interested in solving the problem so you won't see it emerge here. My goals are somewhat more modest than with the Whipple. I am looking for a solid performing car in the 800 rwhp range with improved reliability and that we do not have to accomplish custom fabrication for the core system components beyond the initial Turbo build.
Steve chose the Precision units that have really had a positive reliability and quality reputation in the Honda and Supra world. After several communications with Aaron at Precision we settled on two options, twin 6266 or twin 6766. I chose the 6266 giving up potential growth for a better spool. The units have a 0.81 AR with a T4 flange.
Before we could get to the good stuff we had some cleanup to do with Ethyl.
First, the Mosier pumpkin with the Wavetrac 35 spline Diff could not handle the power the Whipple made. On the fourth 60% throttle pass the Wavetrac disintegrated. There were less than 1000 miles on the unit. At our power level, Mosier/Wavetrac agreed to fix the rear end one time but advised my they could not continue the lifetime warranty. After a very amiable conversation with a gracious representative from Mosier we opted to get our money back on the Wavetrac.
Chris Nichols at GForce Engineering recommended we try a Strange S-Trac. I had considered a spool which I had run successfully at this power level on the OEM differential. However, I broke an LCA while running the spool and prefer not to use one with the IRS. If the S-Trac cannot hold I am going to an SRA.
Next, the battery relocate done when the Whipple was on the car was my first and it was not well done. SNL has taken a couple of weeks to sort out the wiring problems we encountered as we began to bolt the Twins up. We stopped the install on the Twins and went through the entire car rerouting, wrapping, and reconnecting the wiring.
We also pulled the Nitrous kit. That may have been a mistake but for now we are just going to see what the Twins can do. I know where Waco is if I need to reinstall it.
In addition to the above, one of the driving factors on the twins was to have a hood back on the car. So I have bought my eighth hood and it is waiting patiently to be installed.
Most of the Fabrication and patch up work is done. We expect to start tuning next week. Here are a few teaser pictures of the car with the mockups and in some cases, the final fabrication, in place.
Twinturbo 69 640 Zpsbcf31d4b
Twinturbo 65 640 Zps6401db21
Twinturbo 63 640 Zpsde0ee5f2
Twinturbo 43 640 Zps6f0b4972
A Bumblebee is considerably faster than a John Deere Tractor.
wrp wrp
Posted: 08/27/13
05:15 PM
We pulled the heads just to take a look inside, 5000 miles later everything looked okay.
4085000 4 640 Zps5b3b33d1
4085000 2 640 Zps826bb85d
Heads5000 5 640 Zpsb5dd47e1
Heads5000 1 640 Zps5fb2f956
Heads5000 7 640 Zpsb5232079
wrp wrp
Posted: 08/28/13
02:16 PM
Here she is with her hood test fitted
E60d86a8 7Ec5 49Bb A701 2Db2c0a6ca69 Zps69b97475
Cc5e8321 Ec1d 4Ffa 8C6b 2Edfcd7f5100 Zps327aa8cc
wrp wrp
Posted: 08/29/13
06:42 PM
Buttoned the engine back up today. Starting to find small things displaced over time, minor delays, yet irritating. For instance we sat on the fuel rails for three months before discovering the wrong thing was sent.
4085000 5 640 Zpsa31b84f7
4085000 6 640 Zpsdbc6f000
4085000 7 640 Zps7c85f704
4085000 8 640 Zpse529a039
4085000 10 640 Zpsf76e5e65
wrp wrp
Posted: 08/29/13
06:42 PM
Started getting into the good stuff today. Bolting the Turbo up. Everything coated and ready to install.
Twinturbo 37 640 Zpscc6c27b3
Twinturbo 36 640 Zpsec44f3e6
Twinturbo 35 640 Zpseafe97a8
Twinturbo 33 640 Zps6466f2bb
Twinturbo 32 640 Zpsda3dbd65
Twinturbo 31 640 Zps61b57569
wrp wrp
Posted: 08/31/13
03:50 PM
A little more progress today, hope to start by next weekend.
Twinturbo 45 640 Zpsa8c7ca2f
Twinturbo 44 640 Zps728a3bcd
Twinturbo 43 640 Zps24c1ea74
Twinturbo 42 640 Zps8e7ac713
Twinturbo 41 640 Zps0925071e
Twinturbo 40 640 Zps159a0fc8
Twinturbo 39 640 Zpsf08bb186
Twinturbo 38 640 Zpsfe204404
wrp wrp
Posted: 09/05/13
09:03 PM
Stepping up the fuel deliver from the A1000 to the Eliminator. Adding Billet Controller and -12AN inlet/outlets
Fuel 58 640 Zps2102e89d
wrp wrp
Posted: 09/06/13
09:16 PM
Cool shots
Twinturbo 56 640 Zpsd86ac668
Twinturbo 57 640 Zps73fc7102
Twinturbo 52 640 Zps52b535a4
Got the Oil Lines in
Twinturbo 51 640 Zpsce0a25ac
Twinturbo 50 640 Zps3bdb5b3a
Starting on the Fuel System, upgrading the A1000 to the Eliminator
Fuel 16 640 Zps58bd155d
Ford 9 Inch is back where it belongs with the Strange S-Trac in place of the Wavetrac
Ford9inch 56 640 Zps841128e2
Ford9inch 58 640 Zps5fa5c729
Ford9inch 57 640 Zps15a2836e
wrp wrp
Posted: 09/07/13
06:28 PM
Really good day today. The guys got the Turbos bolted in solid and started the fuel system assembly. Just a matter of time now. Barring no more delays we should get a crank up video soon. Here were the major things accomplished:
Fuel System Plumbing
Fuel 64 640 Zps88c69f24
Fuel 62 640 Zpsc1c6ff19
Fuel 65 640 Zpscbe894fe
Fuel 66 640 Zps00b0146c
Girls are all bolted up and bolted on, look kind of perky don't they?
Twinturbo 66 640 Zps76cf50ee
Twinturbo 65 640 Zps1107e6f3
Love how she winks at me
Twinturbo 63 640 Zps1b9ac7f5
Downpipes bolted up with exhaust
Twinturbo 61 640 Zpsc8698127
Twinturbo 62 640 Zps4688ad2b
Twinturbo 60 640 Zps7255781a
Seriously thinking about leaving the headlights out.
Twinturbo 59 640 Zpsb9dddcf6
Addict | Posts: 5172 | Joined: 12/09
Posted: 09/07/13
08:45 PM
She sure does have a hypnotic stare, the eyes just suck you in. Man, you better hold on to your hat. That Whipple was impressive but this package seems more evolved and fits her so much better. As always, the ideas, craftsmanship, and photos all look good. Best of luck with the shakedown period, I think she will be glad to have the hood back one day!
wrp wrp
Posted: 09/07/13
10:21 PM
In all honesty I think the heads and Cam, then Harrop, then Whipple builds were really just a good practice for this one. Seems like things are getting better as we learn more. Thanks for the comments
wrp wrp
Posted: 09/08/13
06:13 PM
Picked up a trailer today.
Trailer 1 640 Zps413fed91
Trailer 3 640 Zps999937c7
Trailer 2640 Zps0378d5ad
wrp wrp
Posted: 09/11/13
06:55 PM
We are down to the wire now. Finishing the final bits and installing the fuel pump controller plus the hood, should start it tomorrow if the shipping gods shine on us.
Twinturbo 67 640 Zps6488ac7d
Twinturbo 68 640 Zps5c2002f1
Twinturbo 73 640 Zps8ddc7cff
wrp wrp
Posted: 09/14/13
07:04 AM
Well the is the 11th first start since I bought the car in 2004. As opposed to the lat build which was my first big build, this one was handled very well buy the shop. Looking forward to the tuning results.
http://www.youtube.com/watch?v=0Do1-HUZ5ic
wrp wrp
Posted: 09/14/13
08:08 PM
ettled the tune today and stopped any leaks we had, going forward we are going to be tuning it seriously
