Pontiac bolt torque specs
Posted: 12/01/13
03:54 PM
APPLICATION                          TORQUE       LUBE incre.
                                350-455
Bolt, main bearing cap to block       100 lb-ft oil 20 lb-ft
Bolt, rear main cap to block            120        oil 20
Bolt, cylinder head                           95 *     oil 20
Bolt, flywheel to crankshaft               95        dry 40
Bolt, oil pan to block                         12         dry 4
Bolt, oil baffle to bearing cap             15          locktite none
Bolt, oil pump to block                      30            locktite 15
Bolt, oil pump bottom cover              15            locktite 5
Bolt, harmonic balancer to crankshaft 160      dry none
Bolt, Fuel Pump to Timing Cover       20/25      oil 10
Bolt, Front Insulators (engine mounts)  75        dry none
Bolt, Rear Insulator (tranny mount)      30        dry none
Bolt,exhaust manifold to head             40        antisieze 15
Bolt, intake manifold to head                40        dry 10
Bolt, front cover to intake                  12        dry none
Bolt, sprocket to camshaft                  40        dry none
Bolt, camshaft retaining plate              20        dry none
Bolt, rocker arm cover to head              8        dry 4
Bolt, clutch pressure plate to flywheel   25     locktite 5
Bolt, converter to flywheel Turbo 400   35        dry none
Bolt, converter to flywheel Turbo 350   30        dry none
Bolt, flywheel housing to block             40        dry 20
Clutch Fork Ball Stud                           40        dry none
Bolt, Trans to Bell Housing                   55        dry none
Lock Nut, Clutch Fork Rod Adjustment   10        dry none
Countershaft Stud AssemblyCylinder Block 70        dry none
Nut, Countershaft Stud to Side Rail       21        dry none
Nut, connecting rod bolt, except 455SD 43        oil 10
Nut, connecting rod bolt, 455SD           63        oil 15
Nut, rocker arm to stud (3/8")             20        oil none
Stud, screw in rocker arm                  55        dry none
Bolt, timing chain cover to block         30        dry 15
Nut, timing chain cover to block         15        dry -
Bolt, timing chain cover to pan           12        dry -
Bolt, water pump to timing chain cover 15        dry -
Bolt - Fan and Pulley to water pump    20        dry 10
Bolt - Pulley to Balancer                     20        dry 10
Spark plug to head (gasket type)       25        dry none
Spark plug to head (taper seat)         15        dry none
Plug, oil drain pan                            22        oil none
Posted: 12/01/13
04:43 PM
Thanks Pman, appreciate it!
Wink
gto66 gto66
Enthusiast | Posts: 489 | Joined: 11/08
Posted: 12/01/13
08:38 PM
Great info Pman!!!
Posted: 12/02/13
11:25 AM
thanks guy's
