My 326 build
My 326 build
thinman56 thinman56
Posted: 06/27/13
12:28 PM
Well, I started out wanting to keep the 326 for my '64 Lemans and build a good street runner, even though I know that there's 'no replacement for displacement'.  In the end I found a '67 326 for peanuts that had already had some of the machine work done and had the slightly better 140 heads.  Then I got a little caught up in the performance parts, but I think this'll be a really smooth street motor.  Thanks to all who provided advice, especially 70bird.  Here's what I got going, some assembly still required:
*1967 326 block, bored 0.060" over, SP cast eutectic pistons, crank ground 0.010" under, SP tri-metal bearings, rotating assembly balanced.
*140 heads, pocket ported and intake matched, will remove any burrs from runners but otherwise will not increase port size, SI SS 1.92/1.66 valves, 3-angle valve job, threaded rocker studs, Scorpion 1.5 full roller rockers.
*Lunati Voodoo 10510701 cam, 213/219 @ 0.050", .455/.468 lift, will install at 108 ICL to start.
*Edelbrock P4B intake w/Edelbrock 14064, 600 cfm carb
*Stock dizzy with HEI kit
*Melling M54DS oil pump
*Summit shorty headers, will probably use a 2.25" exhaust, 2.5" too big?
For now it'll use a TH350 and the stock 3.08 gears.  I have a Muncie 4-speed, but can't afford the rest of the conversion after the motor work!  Got a buddy who builds race engines to help with assembly.  Wish me luck, will post results sometime in August, with any luck...
Posted: 06/27/13
01:14 PM
Hello thinman56
EX PIPE DIAMETER - 2 1/4" ex is big enough but don't forget a cross over tube. An X type is best but overkill in your case.
MUFFLERS
What do you plan for mufflers, quiet, medium, loud?
Loud inside and out or just outside?
Single baffle flowmasters are the most obnoxious in and out, dynomax are straight thru and much quieter inside and slightly quieter outside.
HEADERS - Whatever you buy I suggest the ex flange be at least 3/8" thick. The 1/4" will bend then leak. The cheap ones are commonly thin wall metal and therefore louder than thicker ones. Suggest 2 1/2" collectors, 3" is too large for your app. Looks like headman 1/4" flange is all I can find on Summit.
INTAKE - Make sure the P4B fits your head bolt pattern.
