Electric bath for 1969 GTO hood.
jbmacneil jbmacneil
Enthusiast | Posts: 542 | Joined: 07/09
Posted: 01/25/14
01:12 PM
Hey Guys,
Im thinking about building a little box out of two by sixes and thick plastic, to put the hood of my 69 GTO in and do the electric thing to it to remove some rust I cant get to as well as any trace amounts left from using the DA on it. Also, I should state this is rust that is on the underside of the hood, and I know this is large scale but it should be the same concept right? Like a large peice of rebar for the sacrafical metal, the gallons of water with some baking soda per gallon, the positive side of the battery terminal hooked to the rebar and not in the water, and the negative side of the battery terminal hooked to the hood. Then let sit for a few (days)? in the driveway? What do you all think?? Thank you. JB
Addict | Posts: 5165 | Joined: 12/09
Posted: 01/25/14
06:12 PM
I've never dealt with rust that way but I noticed the other day that a 68 el Camino hood skin could be removed and reinstalled with little damage. If yours is made the same way (spot welded on all edges, with none that wrap past a 90 degree angle), thats another option to consider. It would allow you to sand the insides of everything until clean.
Posted: 01/27/14
11:10 PM
you will need a stainless steel rebar to do that.
i used citric acid in in a home made 6x6 box with a land scape liner to strip the rust off of a 76 formula hood. works faster with warm water. mixture worked real good just don't leave it to long!!
matt i was thinkin the same thing the other day to fix a bent (folded) hood.
marbil marbil
New User | Posts: 45 | Joined: 04/13
Posted: 03/27/14
02:36 PM
I believe you add washing soda not baking soda, I think? The anode is sacrificial it just needs to be steel.
Why not use metal prep?
Posted: 03/27/14
08:54 PM
your right marbil but stainless will last longer.
the citric acid works better it is basicly coolaid without the color and sugar. you can drink it if you like sour stuf!
lemmon juice will work to!
