details on my engine
chadistre chadistre
New User | Posts: 4 | Joined: 07/13
Posted: 07/26/13
10:28 AM
I just purchased a 1972 ventura. It was originally a v6 car but the previous owner pulled it out and there is a 400 motor and th400 in it now. The 400 motor was rebuilt and never used. It has been sitting for ten years. it has and edelbrock intake and hooker headers. As I tore the motor down to change all the gaskets I saw more motifications on the inside. it has been bored 40 over. It has h-beam pistons rods. I dont not know whether it is stroked or not and dont know what to original stroke of a 400 is to measure and see.
The block has gm-5 d n  stamped on it.  by the water pump passenger side top it is stamped xa. Passenger side water pump bottom is stamped 271N32598. I would think that is the serial number. Am I correct? Over the center exhaust port on the heads is stamped 6X. Between the center e haust port and the right it is stamped J156. Can anyone tell me what these stamps mean or where I can find out what they mean. Any help would be greatly appreciated.
Posted: 07/26/13
10:57 AM
I see you are a new member, welcome. The link below has lots of info including free calculators to determine compression and et times etc, very cool.
There should be another number to the left of the exhaust just below the valve cover on a flat small square. Get that and match it to the number on the left of the list.
J156 = Casting date, which is the date the heads were physically made.
J = Either OCT OR SEPT. I don't remember if Pontiac used i as a month code, chevy did not.
15 = day of month
6 = 1976 but due to the month it was cast it is for a 1977 engine.
Based on your info, if the block is orig to the heads your number to the left of the ex port should be either 4 or 6 according to Wallace.
4 6X   93.74 cc's 2.11/1.66 valve 4.86" 350
6 6X 124.51 cc's 2.11/1.66 valve 4.71" 455
8 6X 100.04 cc's 2.11/1.66 valve 4.86" 400
http://www.wallaceracing.com/head1.htm
BLOCK
350 = 3.87 bore, 3.75 stroke
400 = 4.12 bore, 3.75 stroke
455 = 4.15 bore, 4.21 stroke
Sorry, I'm useless on you block, lol.
Posted: 07/26/13
11:27 AM
look at the casting number on the crank to see if it is a factory 400 crank.
October 15, 1976 as 6X heads were not made in 1966.
There is a casting number on the top back of the block as well.
1976 400 170 HP XA A 7.6 255 6X 1-2 17056160/64 Export Block Casting # 500557
1977 400 180 HP XA A 7.6 793 6X 1-4 17057274 FB Block Casting # 500557
chadistre chadistre
Posted: 07/26/13
11:27 AM
Thank you. I will check out the link.
Can anyone be of assistance with yhe block numbers.
Posted: 07/26/13
11:31 AM
"October 15, 1976 as 6X heads were not made in 1966."
Typo, I corrected my post to 1976. Tiny keys on my keyboard.
Posted: 07/26/13
11:36 AM
"Can anyone be of assistance with yhe block numbers."
There is a casting and date code on your block. It might be on the back behind the intake facing skyward around 6" from the distributor position. The casting code is easy to read the date often is not.
Posted: 07/26/13
11:39 AM
Here is that location.
Identify Image003
chadistre chadistre
Posted: 07/26/13
02:34 PM
Ok  I found numbers at the back of the block. There is one on top. 1276. There is a 2 right at the rear of the block. part of the 2 is cut off where it bolts to the tranny. Then there is a number going down the side of the block. 500557.any idea what these are. The number on the crank someone mentioned. Where exactly would that one be located and how would I know if it original.
chadistre chadistre
Posted: 07/26/13
02:36 PM
Duh. I just looked at the picture someone posted saying it is the date code and casting number. What about the two at the top center very back edge of the block. Any idea.
Posted: 07/26/13
03:01 PM
https://sites.google.com/site/ksmsinc/technical-info/title-1/pontiac-v8-crank-identification
