wheels and tire size?
fettracing8 fettracing8
New User | Posts: 16 | Joined: 05/10
Posted: 02/26/14
08:38 AM
I have a 74 GTO (x-body) with tubelar upper and lower control arms and QA1 adjustable coil overs on front, I am looking at buying some 17in wheels for it but i am not sure of the offset/back space i should get and i also want to put the widest tire i can fit in the rear with no rub issues, i am not opposed to rolling the fender lip if need be any suggestions or help is appreciated!
Posted: 02/26/14
08:38 PM
you could use wire to simulate a tire and wheel with the car on jack stands. some tire shops have a tool for this or you can by one.
Percy's 01201 WheelRite Wheel and Tire Fitment Tool Measuring Device 75.00
http://www.ebay.com/itm/Percys-01201-WheelRite-Wheel-and-Tire-Fitment-Tool-Measuring-Device-/400658935860
Addict | Posts: 5168 | Joined: 12/09
Posted: 02/27/14
06:10 AM
Not many guys in here have X-bodies but quite a few have Fs. I had a 71 Ventura II, which is like yours. I had 15s on it with 235/60s, sold it to a friend who put 16s on it and ran 225s (burnout city). Neither of us tried to max out tire size on it but-
Don't expect the same size wheel/tire to fit the same from car to car. Meaning there can be a great deal of variation between "same" bodies.
The lip may need a little work, but limiting clearance on the inside is the leaf spring (if not the inner wheelwell at inner front tire edge). On the outside, its the outer wheelhouse above the center of the wheel opening. Often guys clearance the lip but still rub on the outer wheelhouse. Ride height is a big player on that one. Back space needs to be 4-5". Closer to 5 is better, when dealing with 7 or 8 inch wheel width. I don't think you'll have much luck getting a 275 mm width tire in there without major mods, so I would make 255 width my goal.
As ROWSLEY said, its best to measure your individual car first. Or start with swapping friends' tire combos on there to try.
Addict | Posts: 3965 | Joined: 06/09
Posted: 02/28/14
10:01 AM
If you want the widest tires you can fit, first forget the tall rims - Go with 15's. 10" wide rims out back with 295 BF Goodriches, standard fronts with 235/15's.
You'll need gas or airshocks to prevent the rub, and carefully measured and placed traction bars if rear wheel hop is a problem. The tires will stick out a few inches, but unless you have a narrowed rearend you'll have workable "big tires" without offset/backspace concerns.
69GTOby 69GTOby
Guru | Posts: 1118 | Joined: 02/09
Posted: 02/28/14
07:22 PM
You won't know for sure what fits until you try it.  Also, keep in mind that different brands sometimes have slight differences in sizes.  Two tires of the same size may vary slightly in actual size from brand to brand.  Some tire manufacturers must measure their tires a little differently, and some of it also probably has to do with design.
In any case, what I would do is acquire several different sizes.  Go to local shops and ask if you can take some used tires.  They might actually welcome you, because often shops have to pay for tire removal.  I know we do.   The tires just have to hold air to give you a "mock up" - just something to get you an idea of what you might be able to fit back there.  Maybe get 245, 255, 265 widths.  Focus more on the width.  Once you establish the width you can squeeze in there you can deal with the height.  I assume the car has 15's on it now, which is a pretty popular size.  You shouldn't have problems finding tires in that size.  Once you find the width and the height, you're all set.  Say for example you discover 255/60/15 fits well.  That equates to 255/50/17, that is, they're both 255mm wide, obviously, and 27" tall.  You can use an online tire calculator to play with the sizes.
Like Brazil said, air shocks are nice for easy height adjustment to accommodate taller tires.  Also, when choosing the tire height, keep in mind your final gear ratio and rear gear.  Depending on what you want to do with the car, you can use the tire size to dial in the cars desired rpm's at various vehicle speed.
Posted: 03/01/14
12:43 AM
any of you guys want some air shocks! i think i have 3 sets!! the problem with air shocks is keeping air in them. other wise you cut up 2 130 dollar tires and your car corners like crap when it's jacked up high enough to clear the n-50s!
some of the bigger tire shops will let you try different tire and wheel combos.
you will most likely have better luck on a nova or x body form.
my friend has a 68 firebird with 17x9 4.5 back space. 235/45s in front and 255/45s in rear. the 2 cars have the same sub frames and rear axle width. only the rear quarters would be the big difference.
Posted: 03/03/14
05:35 PM
Yeah the air shocks are not my 1st choice, they do leak down. And the tiny plastic tubes that blow them up have to be routed away from the exhaust, or else instant schooooooooooooooooooooo - clunk clunk, rip rip.
Crazy
I haven't heard about Koni's for a while, they used to be the thing in the 80's.
69GTOby 69GTOby
Posted: 03/03/14
07:53 PM
I hear mostly bad things about air shocks, like how they leak down and don't ride well, and so forth.  Yes they can leak down sometimes and yes they can be rough when you pump them up to 120 psi, but the leaking down is not a big deal and with moderate pressure they ride quite well.
My Dad put air shocks on our '69 GTO some 25 years ago.  We never had a problem with them.  We had to air them up every once in a while, maybe as often as you air up your tires, about every oil change, no big deal.  I had one incident when something in the trunk hit the inflation valve and busted it allowing all the air to leak out.  But, just don't mount the valve in the middle of the trunk floor, LOL c'mon Dad... hahaha
Posted: 03/04/14
08:46 AM
Ha, yeah maybe not the best spot!
My '79 Trans Am's have a convenient hole, just the right size for the valve. It's on the section of frame that holds the back bumper on, just behind the license plate.
I've kind of gotten away from the widest tires in favor of the more stock look, but sometimes that extra traction is helpful..
69GTOby 69GTOby
Posted: 03/09/14
09:54 AM
Right on, Braz.
Just figured I'd throw this in...  I am putting some air shocks on my truck.  I am planning on putting the valve behind the gas tank door. That way it is well protected!
