Could use some guidance on rebuildinbg my 1969 428 engine
70 GTO Convertible 70 GTO Convertible
New User | Posts: 1 | Joined: 03/14
Posted: 03/30/14
08:26 PM
Hello,
I am new to this forum. After reading some of the tech suggestions to questions from other Pontiac enthusiasts, I thought that I should seek some help before rebuilding my 428 motor. Specifically,I am looking for suggestions on camshaft selection, compression ration and head selection.
Some info about the broken engine itself. It is 1969 428, Code YH motor that came out of either a Bonneville or Catlaina, I'm not sure. I do know that it has @ 68,000 original miles on it. It has never been taken apart. It has "46" heads and a stock 4 BBL intake. The engine ran beautifully and made some nice power ....everything was fine....until....
I got a little bit carried away last summer while driving my 1970 GTO and ended up breaking a piston and ring. I have decided to rebuild the engine completely.
The new engine will be going into my 1970 GTO ragtop. The GTO has an M-20 4 speed and 3.42:1 posi rear end.  I am weekend and summer cruiser who like the engine to be a wee bit beefier than stock.  I am thinking @ 450HP without doing any really radical machine work or components.
I plan on using the 428 block/crank and upgrading to forged rods and pistons.
For heads, I am thinking of ditching the small valve "46" heads for a set of either casting # "12" (from a 1970 400 cid) or  #"64" (from a 1970 455).  I am hoping to end up with compression @ 9.5:1.
Camshaft: no idea...I am open to suggestions.
Intake & carb: orig cast iron 4 bbl and Q-Jet.
Thoughts and comments - thank you
Ed from Boston, MA
Posted: 03/30/14
10:58 PM
HI
Do you want a lite to lite drag car, freeway flier or in between?
mild, moderate or rough idle?
tire warmer or tire burner?
low, mid or high revver?
Your 450 hp goal is more than just a "wee" bit over stock, lol.
CAMS - lunati 60903 with stock intake and carb = not 450 hp.
https://www.lunatipower.com/Product.aspx?id=2355&gid=287
comp cams xe274h lunati 60904 with eddy rpm intake and a real carb.
https://www.lunatipower.com/Product.aspx?id=1777&gid=287
CARB - Buy a vacuum secondary annular boost venturi type like a holley or quick fuel.
HEADS - Get them pocket ported and have the intake valves back cut.
COMPRESSION - 9.2 - 9.5 is a good number imo.
ROCKERS - Scorpion "race" model full roller from summit.
CRANK DAMPER - Get an sfi certified one. Pioneer/durabond make reasonable priced ones but the ATI brand is far superior.
ENGINE BALANCE -Get it done
Posted: 03/30/14
10:58 PM
welcome! this may help.
http://forums.highperformancepontiac.com/70/8747136/the-general-discussion/dawnas-406-433-build-a-tribute-heaven-can-wait/
the 64 heads at 87cc will be a good choice. 0 deck the block and you will be close to the 9.5 mark. the 64s will need to be ported to make 450 hp or you could use eddlebrock heads.
performer rpm intake.
cam somthing in the 227/233 at .050 lift range.
any carb in the 800cfm range
Guru | Posts: 1247 | Joined: 02/10
Posted: 04/01/14
05:34 AM
Hi Ed,
Your orginal HP figure from the factory was 360 so getting to 450 shouldn't be too hard. although some of that 360HP came from 10.5:1 CR.
Not sure what kind of $ figure you want to spend, but here are some thoughts..
The orignal cam for this from Pontiac was the 066 cam.. Rather tame..
They also offered the 068 cam for the higher HP versions of the 428. Aftermarket cam that is close to those;
http://http://www.crower.com/camshafts/pontiac-287-455-v8-torque-beast-hydraulic-278h.html
Or something similar in specs.
Definitely go with the 64 heads.
Consider port matching intake and and heads and go with the Ram Air repro exhaust manifolds, unless you sepcifically want to go with long branch headers (which will help in the HP department)
If you have the $, then I'd opt for Edelbrock aluminum D-port heads.
The Q-jet can be tuned to give you exceptional performance, but you'll need patience and a written guide as they aren't the easiest things to work on.
Given that you broke a ring and piston, chances are you'll need some cylinder work. Going .030" over w/ the 64 heads  and zero decked block will give you about 9.7:1 CR which is still doable w/Iron heads. w/.020" on the deck height, instead of zero, you'll get about 9.3:1 CR. If it were me, I'd leave the deck hieght as it is and bore the block to get my CR. That way, it will give you more room for just that little bit of higher lift cam for more breathing.
For the bottom end, which crank to you have? the Arma steel? or the later N (nodular iron)?
Definitely have the bottom end balanced after you obtain the rods/pistons.
Stay with a flat top piston.. Not necessarily forged, but the extra strength wouldn't hurt. Have the machine shop weigh the reciprocating and rotating mass and calculate safe RPM levels. You might look into verious methods of strengthening the crank shaft (shot peening, etc..).
To get your 450 target @ ~9.5 CR, it's all about breathing.
the 428 lends itself to higher RPM's with the shorter stroke/bigger cylinders, but this motor can be a torque monster also.
Just my 2-cents.. Might only be worth 1 cent.. lol
