Is this going to work? New to this!!!
tyeopalinski666 tyeopalinski666
New User | Posts: 5 | Joined: 04/14
Posted: 04/19/14
01:04 PM
l
Posted: 04/19/14
02:23 PM
Is there a Pontiac engine in the Ford f250 ?
Posted: 04/19/14
08:25 PM
WTF?
Posted: 04/20/14
05:21 AM
LOL! The truck has a FORD 400M and a C6 automatic, seriously you are better off with the 267 engine that came in the Firebird! That 400 Ford is a wheezer piece of $h!t! You can't possibly be considering such a swap, can you?
Since the Firebird is already equipped with a 267 small block Chevy (yes, they came that way up here in Canada), the easiest swap is to bolt in a 350 Chevy for an instant power increase. All the accessory brackets, wiring, fuel lines, transmission and exhaust will bolt right on. To swap in a REAL Pontiac 400 will require finding a complete late 70's Firebird or Trans Am that you can get all the parts from. You will have to change the motor mounts on the crossmember and use the block brackets from the donor car, reroute the fuel lines to the driver's side (Chevy powered Birds had them on the passenger side), use the wiring harness that comes with the donor, swap the battery and tray to the driver's side, switch to the transmission from the donor unless the original has a dual bellhousing pattern. You will also need all the accessory brackets for the Pontiac engineincluding the power steering pump and hoses because they are differentas well. I could go on and on but as you can see, it's hard enough to switch the car from Chevy power to true Pontiac power let alone swapping a non-GM drivetrain into it. I really hope this was a late April Fool's joke!
Posted: 04/20/14
11:35 AM
probably the original ford motor im guessing
Posted: 04/20/14
11:45 AM
and how the *** should any of this *** i know i have no clue about swapping motors in cars thats why i asked a question. give me a break you *** clowns
Posted: 04/20/14
11:46 AM
i have no clue about any of this swapping *** so just give me a break. thats why i asked
Posted: 04/20/14
11:46 AM
Posted: 04/20/14
11:54 AM
I think I see what has happened. Man needs a 400, searches and finds one at the right price. But its a Ford. We experienced Pontiac lovers might not imagine that there are folks who don't know better than to assume a 400 is a 400 and a 350 is a 350. A person should study any vehicle they intend to purchase, but sometimes brand specific knowledge is assumed to exist. For example, I have met several people who had no idea that 350 Chevy, Buick, Oldsmobile, and Pontiac engines are all unique designs. Unlike the modern trend of common powerplants for several brand names of new vehicles, and porobably confusing to those born after the last Pontiac 400 was cast.
The Ford engine is not a suitable replacement for any Pontiac. It would be a custom engine swap with fabricated parts.
Posted: 04/20/14
11:56 AM
Easy with the name calling, thats a two-way street you're on ...
Study up or find a Chevy to use. Get lost if you're gonna mouth off.
Posted: 04/20/14
07:42 PM
Wow, I'd say "you're welcome Tye" but I didn't hear a "thankyou" anywhere in your response. I find it difficult to believe that anyone with half a brain would think that a Ford engine is the same as a Pontiac engine, especially given the age old GM vs Ford vs Mopar rivalries. I'm pretty certain that it's fairly common knowledge in North America that the big three didn't share engines so I'm not sure what game Tye is playing.
Posted: 04/20/14
07:45 PM
Funny thing, I just looked back and he's already editted out his entire original post where he asked if the two Kijiji listings would be compatible, one an 81 Firebird and the other an 80's Ford F250. Guess we know what game was being played.
Posted: 04/20/14
08:41 PM
I simply didn't understand his question. I might have helped if he had formed a coherent sentence.
Barneyformula
"I find it difficult to believe that anyone with half a brain would think that a Ford engine is the same as a Pontiac engine,"
100325 Brain Model Hmed 530A
