help me with vacuum port on intake manifold
sick66one sick66one
New User | Posts: 2 | Joined: 04/14
Posted: 04/15/14
10:15 PM
I own a '68 firebird 350
I go to start her up after sitting for a while. It takes a moment but when she fires up, I hear a small pop and *hiss* I'm late for work so I lock her up and look at it the next day. I open the hood, start her up and find an open vacuum port on the intake manifold that is sucking air. I figure a hose must have came off, but upon my inspection I find no disconnected hoses. My question, is it suppose to be capped off? Or do I need to take a better look cause a hose absolutely connects to it?
I am ashamed, I should know my engine better than this.
2014 04 15 211901 Zpsf28c6211
M-22 M-22
New User | Posts: 10 | Joined: 08/13
Posted: 04/16/14
03:14 AM
That looks like the PCV port where the hose from the valley pan would hook up to. But I see that it's run to the front of the carb. so I imagine that they just had that port plugged. Now I'm going to have to go out and take a look at mine to remember. lol
Posted: 04/16/14
04:46 AM
Yep that needs to be plugged. Must have either had a cap over it that finally got so soft that the engine sucked it in and ate it, or maybe it had a backfire while starting and blew the cap off. You might look around under the car for it. Those caps sure don't last very long.
Posted: 04/16/14
03:10 PM
If it is a screw in type unscrew it and get a screw in plug that way you will not have to keep replacing vacuum caps.
sick66one sick66one
Posted: 04/16/14
07:55 PM
Thanks for the responses guys. I will get her plugged up right away, I will make sure to check if its threaded, it would be nice to have a more permanent solution.
Enthusiast | Posts: 470 | Joined: 11/13
Posted: 04/18/14
05:21 AM
why do you have 2 vacuum lines going to the front of your carb?
is the distributor vac going to ported or manifold vac?
