Auto to Manual trans question
lpaulmorgan lpaulmorgan
New User | Posts: 31 | Joined: 01/14
Posted: 04/28/14
06:45 PM
I'm putting a Tremec 5 speed in my 68 Bird and was wondering if there is anything special I need to do to get the pilot bearing into the crank. The car originally came with a power glide.
PLEASE don't tell me that I have to pull the crank and have it drilled!!!!
C_U_L8ER. C_U_L8ER.
User | Posts: 118 | Joined: 05/11
Posted: 04/29/14
06:05 AM
Nice choice!  This trans has overdrive as well.  I actually ordered one for my rebuild as well, but because of an extraordinary leadtime and the fact I already paid the bucks to have my TH400 rebuilt, I stayed with automatice.  I hope I don't kick myself for it.  Unfortunately, I don't know for sure since I didn't do it, but regardless it will be worth it IMO.  Good luck.
Posted: 04/29/14
07:50 PM
no it should drive right in to the crank if you have the right pilot bearing.
witch tremec did you get? i love my tko 600!
Posted: 04/29/14
10:15 PM
I went with a nicely used 3550. It was a really good deal that I couldn't pass up. If I ever exceed the torque rating I will have to step up to the newer TKO600, but with street tires I think I'll be fine.
Posted: 04/30/14
11:12 PM
whats the torque rating on the 3550?
Posted: 05/01/14
06:21 AM
It is listed as a constant 450ftlb torque rating. The new TKO600 is listed at 600ftlb. I'm sure it's plenty strong for my street car.
crankor crankor
New User | Posts: 8 | Joined: 07/12
Posted: 05/13/14
04:06 PM
Is it weird that my pilot bearing slides right into my eagle crank with no resistance??
User | Posts: 151 | Joined: 05/14
Posted: 05/14/14
12:59 AM
I have read that some cranks were not machined for pilot bearings.  Frown
http://books.google.com/books?id=iBPFB0nDuEwC&pg=PA35&lpg=PA35&dq=are+all+pontiac+cranks+machined+for+pilot+bearings+?&source=bl&ots=SYtBJU7Gad&sig=8A67JNPrDX8mgfms--e2rxx8cug&hl=en&sa=X&ei=syBzU_P1H46NqgamjoGYAg&ved=0CEYQ6AEwAw#v=onepage&q=are%20all%20pontiac%20cranks%20machined%20for%20pilot%20bearings%20%3F&f=false
http://www.wallaceracing.com/Pontiac%20Cranks.htm
http://speedtalk.com/forum/viewtopic.php?f=1&t=27534
BOP has the correct size bearing.
http://www.bopengineering.com/beltdrive_acc_topend5.shtml
