rear main seal oil leak
jkell jkell
New User | Posts: 6 | Joined: 07/13
Posted: 06/17/14
01:15 PM
Hi Guys!
I have a 455 4 speed 70 GTO. When I purchased the car, it had an oil leak. The rear main rope seal was leaking, so I had it replaced with another rope seal. After several hundred miles, the leak reappeared. I then had the rope seal replaced with a 2 piece viton seal. Again the leak reappeared after several hundred miles. Can someone please offer me advice on what I can do to stop this continueing problem?
Also, is it recommended polishing the searations off the crank shaft when using a non rope seal?
Thanks in advance,
jkell
Posted: 06/17/14
01:28 PM
hello butler performance sells bop one piece seal. it has one cut i it instead of two and have been said to work. the searations are ok.
jkell jkell
Posted: 06/18/14
02:30 AM
Thanks shyrgfuh3 for your response. I appreciate it.
jkell
1979TA461 1979TA461
User | Posts: 63 | Joined: 06/13
Posted: 06/20/14
08:09 PM
I just used a one piece seal from Butler about 6 weeks ago, it hasn't leaked a drop since.  I left the sarations  on the crank with no problems.
