filler on poly primer
akpd akpd
New User | Posts: 28 | Joined: 08/13
Posted: 07/01/14
06:21 PM
Hi Guys,
I just finished shooting a couple coats of poly primer and after words found a few low spots that will not sand out. The questions is, can I put some filler over the poly (slick sand) then continue on or do I have to sand it back down to the epoxy?
Thanks,
PD
Restoring 68 Bird (coupe)
Addict | Posts: 5144 | Joined: 12/09
Posted: 07/01/14
07:44 PM
It would be preferred to use your 2K glazing putty (like Evercoat's "Metal Glaze") over the primer, rather than the bodyfiller. Due to the fact that it's porosity is more similar to the primer. If its deep enough to need bodyfiller, I usually sand the polyester primer away for that. Just down until you hit either filler or epoxy.
akpd akpd
Posted: 07/02/14
03:18 PM
ok thanks, I'll look into that...
Posted: 07/02/14
06:49 PM
Didn't mean to make you have to dig for info.
My statement "checks out" ...
I don't know what brand of materials you are using so I used Evercoat as an example. Similar info is available on any product out there.
Evercoat's Rage Gold bodyfiller for example-
0001446 Evercoat Rage Gold Body Filler Gallon
-does not mention use over primers in it's technical data sheet, as seen here:
http://www.evercoat.com/imgs/pis/PIS%20-%20Rage%20Gold%20rev%20122010.pdf
Evercoat's Metal Glaze ...
P19029
Does mention superior adhesion over catalyzed primers, as seen here:
http://www.evercoat.com/imgs/pis/PIS%20-%20Metal%20Glaze%20rev%20052011.pdf
That should clear it up! Of course, check product info on the stuff you have in hand, products vary.
akpd akpd
Posted: 07/03/14
08:13 AM
Thanks for the response, rage gold is what I use.. tech sheets are the first thing I review then forums etc. for "real world" input.
Thanks so much for your input.
PD
Posted: 07/03/14
01:02 PM
You're welcome as always.
Now that we have established proper procedure for the interweb record ... we can play in the real world!
Man, if all you have is some little spots, say no bigger than 3" or so, not out in the middle of a hood or something, and there's no glaze coat in the house, and you are gonna prime over it again, by all means wipe the little spots and go on. You'll probably have to scrape a second application over the first once its blocked out, due to pinholes. Rage Gold is pretty good for fixing pinholes in itself, I rarely use glaze until after priming.
Theres a difference in what a guy can recommend and what he can do in the shop if you catch my drift.  Wink
Keep it small and prime it good, you won't have a problem.
