Exhaust for my Caddy
69GTOby 69GTOby
Guru | Posts: 1114 | Joined: 02/09
Posted: 07/16/14
04:40 PM
I wasn't sure where to post this thread...  I just bought a '90 Cadillac Brougham a few months ago.  It's in great shape, has 59k miles, and the 350 TBI Chevy engine.  I modified the air cleaner and I'm in the process of upgrading the TBI.  I need to replace the exhaust.  The y pipe is more like a "t" pipe and with only a 2 1/4" collector.  I found this y pipe "Walker 40315" which is for a '92 Caprice.  It also has the 2 bolt flanges, appears to have the same general shape but sports a more favorable merge and a 3" collector.  Does anyone know if this will bolt up to my manifolds??
Posted: 07/16/14
05:28 PM
Hmm. I bet nobody here will know that one. Waynecyclopedia is out of commission but I bet he could find out, if he wasn't. I googled B-body forums and once you sort out the Mopars, theres an active forum or two, such as: http://www.gmbbodyforum.com/ which was the top search result. I bet somebody there would know. If I had to guess I'd say yes, at least if it doesn't fit it shouldn't need a whole lot of modification. But who knows, GM was crazy about specific manifolds for all the different cars. Personally I'd have something custom bent to fit and installed at a muffler shop, especially if the original stuff has never been apart.
69GTOby 69GTOby
Posted: 07/19/14
10:07 AM
Thank you idrive.  I went to a GM forum: GMforum.com and posted there.  I got a little feedback.  I think the only way I will know for sure is to try it...
Besides the y pipe, I want to replace the entire system, preferably with 3".  Pretty much no one makes an exhaust system for this car, stock type or otherwise.  Could I get a system for a different car that would work, or at least be close?
It's rusting out and needs replaced.  I need to put something in it's place...
Posted: 07/19/14
05:13 PM
I must be not seeing the 800 pound gorilla in the room, maybe its hiding behind the curtain.
Why not go to a muffler shop? They make pipes to fit, on the spot. Fairly cheap labor.
The only time I have used pre-fab exhaust is for insurance wrecks on late models. Searching for a direct bolt-in for a 90s Chevillac seems like an exercise in futility. You might want some mandrel bent sections for the over-the-axle part of the tailpipes but other than that, custom bent is the way to go in my opinion.
