TH400 not shift right after engine upgrade
FlashGA FlashGA
New User | Posts: 39 | Joined: 01/11
Posted: 12/04/13
04:26 AM
1975 Pontiac Grand Am 455 with TH400.  Trans ran fine and shifted good barking the tires on the 1-2 shift.  Upgraded the engine to 550 hp / 570 tq.  Now the trans shifts almost immediately from 1-2 and the 2-3 shift is weak.  So, what is going on?  Thanks for any and all help!
1975 Pontiac Grand Am 455 550 hp TH400 3.73
1989 Pontiac GTA
448 hp 492 tq
11.794 @ 117.2
Top Speed over 180 mph.
RIP - Son totaled it!
Enthusiast | Posts: 465 | Joined: 11/13
Posted: 12/04/13
05:00 AM
well if it sat for a few years the trans might have gone bad however i think it is more likely that your modulator on the trans either does not have vacuum going to it or it has gone bad.
it is a small external vacuum can. you can check it with a vac pump or just suck on the hose that goes to it to see if it is leaking or not. should be a simple fix.
it is also possible that you now have a different amount of vacuum going to it therefore you either need to adjust it or get different one. i think they have 3 different ones. one is plain, one has a white band on it and the other might be blue or red.
Posted: 12/04/13
07:22 AM
flash you may need a modulator that works with the lower engine vacume. i think the purple band is the one for low vacume but not 100% shur.
a bigger stall converter will soffen the shifts.
FlashGA FlashGA
Posted: 12/04/13
08:08 AM
Thanks for the replies.  The car has been sitting for about a month now, but I drive it every couple of weeks usually.  The way I understand it is if your modulator goes bad then the engine will shift very late, not early.  But I will definitely check on it.  Also we put a 2500 stall converter in it and I foot braked it to 2400, so I am pretty pleased with the selection.
1989 Pontiac GTA
448 hp 492 tq
11.794 @ 117.2
Posted: 12/04/13
09:11 AM
the transmission modulator controls the line pressure inside the transmission..
the line pressure pushes against the governor piston in an attempt to hold the weights in as it spins..  when the weights spin fast enough to over power the variable line pressure it shifts to the next gear...
when your modulator fails..
gets any kind of vacuum leak...
gets hooked up to OTHER than Manifold vacuum...
gets hooked to to a vacuum port that has a vacuum leak on a different fitting...
gets hooked up with rubber hose instead of a almost metal to metal with a hose sealing the connection at the top end and a short section at the modulator... you can experience the changes in manifold vacuum change the diameter of the vacuum hose.. this delays the vacuum signal to the modulator diaphragm..
as somebody mentioned above...
disconnect the modulator vacuum hose/connection at the back of the manifold..
either use something like a hand vacuum pump from a brake bleeder kit or just suck on the end of the hose and then cover the end with your tongue tip.. it should hold vacuum...   if you wiggle the vacuum you create with your mouth.. you might actually hear the modulator move..
next.. start the engine with the modulator hose disconnected.. you should have a MAJOR vacuum leak..  enough to make the engine idle bad..
next... hook the modulator tube back up to the intake.. and disconnect it from the modulator.. start the engine again..  you should have almost as big a vacuum leak as you did when you disconnected it at the manifold..
one day.. i had a customer come in and his TH400 was not shifting.. i had no place to put his car and he did not want to leave it..   so i sent him directly to my favorite transmission shop.. to get the modulator replaced..  they did so.. but it did not shift.. tried to sell him a very expensive rebuild on the transmission.. so he called me back.. the next day.. i performed the under car test. with the hose off the modulator.. and it did not flow any vacuum from the end of the open tube with it disconnected from the modulator and the engine running.
seems the smog guy.. moved the vacuum hoses around. and used a plastic TEE in the extended modulator rubber hose he installed and had the TEE directly over the crossover heat passage on the intake manifold ..   the underside of the TEE has melted and shrunk in.. sealing off the vacuum.. but looking perfect from the top..
after you verify the vacuum and FLOW to the modulator is significant.. and the modulator and tube/hoses hold vacuum..  you will need to adjust the modulator ..
depending if you have the big can with the screw in the end.. or the small version again with the screw on the end..  you will need to adjust the screw.. no more than 1/4 turn at a time..  this is done during road testing.. so create a wooden ramp with a stop or drive one wheel up a curb in a driveway to allow you to slide under for 20 seconds to give the screw another quarter turn...
FlashGA FlashGA
Posted: 12/04/13
10:07 AM
Wayne, thanks for the detailed reply, but my transmission problem is not that it won't shift.  It shifts almost immediately from 1st to 2nd under any load.  Then the second to third shift is weak.
1989 Pontiac GTA
448 hp 492 tq
11.794 @ 117.2
69GTOby 69GTOby
Guru | Posts: 1114 | Joined: 02/09
Posted: 12/04/13
06:33 PM
The modulator is more for part throttle shifts.  You can get an adjustable one, if you don't already have one, and play with how early or late, hard or soft the part throttle shifts occur.
WOT shifts are "governed" by the governor.  Using centrifugal force, the weights will flare open as speed is increased.  Once centrifugal force overcomes the spring tension holding the weights in their closed position, fluid is redirected and causes an upshift.  Since your car is shifting "immediately" under "any load" I would suspect that your governor is stuck.
The governor is behind a cover fastened by four 1/2" bolts at the right rear area of the trans.  Pull it out for inspection.  Make sure everything looks normal, moves freely, cleanliness, etc...  Clean it with Brakleen or carb cleaner if it's all gummed up.  Be prepared to lose ATF when you remove the access cover.
That's my .02.  I am no expert, but hopefully that helps.
Posted: 12/04/13
09:21 PM
FlashGA (by the way- big Grand Ams are cool  Cool  ) - I don't think I can add anything but wanted to say mine does the same thing. Immediately shifts out of first, that is. I don't think the tire even makes a whole revolution before she shifts to second. The only thing I might add is to check the function of the electric kickdown switch over the gas pedal and also the kickdown part inside of the trans.
69GTOby 69GTOby
Posted: 12/05/13
06:23 PM
Actually, I second that...  Mine shifts into second real quick as well.
The thing that sounds off is this, "It shifts almost immediately from 1st to 2nd under any load."  If that is true, under heavy load, like WOT, it still shifts almost immediately, something is wrong.
Posted: 12/06/13
12:11 AM
Yep, GTOby now wide open is a different story. Most stock or mild TH400s I've met want to shift 1-2 under WOT at around four grand in Drive. Mine does that. After all, they are heavy cruiser transmissions. I select manual low when it counts. The OP may actually have a hurt transmission somehow coincidental with the power upgrade if its shifting real early under heavy throttle.
Posted: 12/06/13
12:12 AM
flash did you change the gears in the rear end? that will have an effect on the shift points. the gov would make it shift sooner with lower gears.
was the trans built for that much torq?
how does it feel when manuely shifted?
