Replaced oil pan gasket, 50psi at gauge but no oil at lifters now?
Marankie Marankie
New User | Posts: 5 | Joined: 12/13
Posted: 12/14/13
10:38 AM
Hey Pontiac Gang,
Maybe you can shed some Pontiac wisdom on my situation. I yanked my Pontiac '71 350 out of my '65 Tempest. I needed to A: replace the oil pan gasket and B: drill and tap the heads for the outer header flange bolts.
So the motor was upside down for about a week until I could complete these tasks. Everything went well, buttoned up the pan, filled with oil, installed new headers, plopped the motor back in, primed 'til I saw 50psi, but not oil coming up to the rockers?
Did I miss a step in getting oil up top?  Did something occur when it was upside down? Should I assume it is just debris in the system somewhere?
I'd hate to have to yank it out again to diagnose.
Any help would be most appreciated.
Thank you,
Greg
Posted: 12/14/13
11:49 AM
The lifters might of collapsed .I would try starting it up and see if they pump up and you get oil to the rockers .
Marankie Marankie
Posted: 12/14/13
12:52 PM
Thanks Jack, I actually have had it running a few times for a minute or so. Still nothing coming up.
Posted: 12/14/13
03:32 PM
Was it making any noise ? What was the oil pressure when running ? It might take longer than a minute to get oil to the rockers .If it has good oil pressure and making no noise run it longer .Oil might be cold and heavy and lifters need to pump up .
Marankie Marankie
Posted: 12/14/13
04:03 PM
No abnormal noise when running, sounds fine, pressure is over 50. There are loud clicking sounds for a minute or two coming from under the valve covers after I shut it down. I was assuming the it was the dry springs and rockers settling?
Posted: 12/14/13
05:56 PM
I would run it ,take the valve covers off and see if all the rocker are working check for loose rockers and if it doesn't pump up and all the rocker are working then I would replace the lifters .
Marankie Marankie
Posted: 12/14/13
06:24 PM
Cool, thanks Jack.That's interesting, the entire rebuild has less than 3000 miles on it, was running great too. Is it possible I damaged the lifters having the motor sit upside down? Perhaps it's just coincidental.
Posted: 12/14/13
11:25 PM
before replacing lifters remove push rods to see if they are clear.
if your lifters do not tick they are at least working. turning it upside down did not do mechanical damage but it might have caused some debris sitting on the bottom of the lifter to plug a few.
it is impossible that they all would of gotten plugged.
you absolutely have oil to your lifters otherwise they would tick loudly after around 10 seconds.
Poncho462 Poncho462
Posted: 12/14/13
11:51 PM
I just did the same exercise( engine out, upside down on engine stand about 10 days, replaced oil pump, pan and new gasket).  I also primed with drill motor, saw 50 plus pounds, fired it up, don't really remember any ticking, but I ran the drill motor several times for a total of about 3 minutes because I wanted the new pump to fill all the drained lifters and passages.  Fired the first time and no noises.  My engine has a little over 10,000 miles on it, and I have now run it about 20 miles in several short trips including freeway with no issues, noises or leaks.
I offer this story merely to show that unless you can think of something else you may have done that you haven't mentioned, it would seem that there is no reason to expect a blocked passage just from being upside down.  Mine was fine.  Did you do anything else?  Or find anything in the pan unusual?  Did you remove the filter adapter to aid engine removal?
Maybe if not too noisy, you might try running it a little longer.  What is temperature you tested at, and oil weight?  If cold and heavy, might need to warm up to flow well enough to get everywhere up top.
Good luck!
Posted: 12/15/13
05:29 AM
How did you set your lifter zero lash? If per chance it is too tight, it might  not be letting the lifters pump up. I am assuming you have hydraulic lifters? What brand of lifters do you have? Comp has had some issues with their lifters.
One thing you can is like Jack said, start it up and see if you have any oil to the rockers. If not you can loosen each one in turn until it clatters, and see if you start to get oil through the push rod and then set your zero lash.
Marankie Marankie
Posted: 12/16/13
08:15 AM
Hey guys, false alarm, I let the motor warm up to 160 and I started getting oil up top.
Apparently some premature paranoia, I guess its better than possibly ruining a perfectly good motor by not knowing.
Thank you very much for all of your input!
Greg
Posted: 12/16/13
09:22 AM
hello good to hear.
how cold is it there?
if it's around 20 - 50 degrees f when you drive, i would run 10w - 30 oil with high levels of zddp. if its below 20 deg f, then 5w - 30.
i would not run 20w - 50 unless it's above around 80.
the lower number allows your oil to flow more easily then a high one, this is beneficial in cold climates.
Poncho462 Poncho462
Posted: 12/16/13
09:17 PM
Glad to hear things evened out without trauma.  Perhaps a combination of relatively low temperatures, slightly heavy oil for conditions, and a fairly new, "tight" engine just added up to needing some temperature to push that oil everywhere it needed to go.  Congratulations on a happy resolution!
