Valve train Geometry.
Moderator | Posts: 5771 | Joined: 02/08
Posted: 12/16/13
08:12 AM
1 The first step is to install a solid lifter and an       adjustable pushrod. Mark the tip of the valve with a marker.
Verifyvtgeometry1
2 Install your rocker arm and set it up with zero lash. Rotate the crankshaft clockwise several times. Remove the rocker arm. The contact pattern of the rocker tip will be where the marker has been wiped away from the valve tip. The pattern should be centered on the valve tip, and as narrow as possible. If it is not, experiment with varying the pushrod length to yield the best pattern.
Verifyvtgeometry2
3 Rotate the crankshaft clockwise several times. Remove the rocker arm. The contact pattern of the rocker tip will be where the marker has been wiped away from the valve tip. The pattern should be centered on the valve tip, and as narrow as possible. If it is not, experiment with varying the pushrod length to yield the best pattern.
Verifyvtgeometry3
4aPushrod Too Long: Notice how the pattern is wide, and shifted to the exhaust side of the valve tip
Verifyvtgeometry4a
4bPushrod Too Short: Notice how the pattern is wide, and shifted to the intake side of the valve tip.
Verifyvtgeometry4b
4cPushrod Length Correct: Notice how the pattern is narrow and is centered on the valve tip.
Verifyvtgeometry4c
