301 turbo to 455 engine swap
MrFitz MrFitz
New User | Posts: 8 | Joined: 01/14
Posted: 01/20/14
11:36 AM
new guy here
I have a 1980 turbo TA and am getting ready to pull the motor.  I will be replacing it with a 1971 YC code 455.  My question is what brackets do I use for the AC.  I intend to put the 1980 AC pump in as the lines are all there and in great shape. Will the 1980 brackets fit or do I need to mix and match the 1971 brackets?  Also i was wondering which motor mounts to use or are they the same?
Posted: 01/21/14
07:10 AM
You're OK with the motor mounts.,. but I'm not too familiar with the AC bracket swap.
I'm sure they're close and can be modified to fit.
Should be a fun car, once it's all done and running.
shyrgfuh70 shyrgfuh70
Posted: 01/21/14
07:52 AM
contact frankspontiacparts.com. they will know and also have the parts.
MrFitz MrFitz
Posted: 01/21/14
01:54 PM
after further inspection, I am pretty sure the 80 brackets wont work as there are two bosses on the pass side manifold that offset the bracket.  I was hoping to use the existing lines .  I am finding that I will be ripping out most everything including the electronic spark control  and just re-wiring and plumbing what I need.  Does anyone know if I could just use a 70 or 71 underhood wire harness and if it would plug in to my harness to simplify things.  The heat from the turbo  pretty much dried out all wiring under the hood.  I have two 78-79 style 403 scoops and one complete 403 base any tips on converting them to fit the 455??  I know the ring is offset and the front edge height is different. The Turbo Hood is up for grabs, any takers?
Posted: 01/21/14
02:35 PM
Most of the stuff off the 301 will not work the brackets are different the only thing that may work is the pulleys and p.s. pump.
MrFitz MrFitz
Posted: 01/21/14
06:33 PM
Ok You are right I knew that the 80 bracketry was mostly wrong for the 455.
I saved all the accessories from the grandville that the engine came from and will use those. But, I was hoping to use the original AC components from the 80 TA as they are practically new, lighter and more compact. I will mix and match to get the AC pump bolted up.   My biggest concern right now are the motor mounts.  Which mounts do I get?  Can I use  top half of the  455 mounts with the bottom half of the 301 mounts?  If so what year 455 mounts do I buy, the parts store shows several #s? Obviously I would buy new top halfs as the rubber is 40+ yrs old.
MrFitz MrFitz
Posted: 01/21/14
06:34 PM
I am sure it is less complicated than it seems but I am working in a one car garage with a drop light at night!
Posted: 01/21/14
06:56 PM
I pulled a 400 out of my 75 T-A to rebuild and dropped a 301 in temporarily for mobility.,. the 400 top mounts bolt to the 301 and are solid steel, the bottom has the rubber cushion, but can be a pain to remove.
Everything fit up well none the less.
MrFitz MrFitz
Posted: 01/21/14
07:45 PM
Good to know
I still have to get the 301T out.  I spent an hour just getting at the top tranny bolts and another deciding whether to cut the downpipe from the turbo.  Exhaust was welded at every junction so out came the sawzall.  Going out in the garage now to remove more parts and put them in freezer bags  it will be a short nights work as it's 16 degrees here and   There's no room to light the propane heater with all the parts I have collected in my tiny garage. And they call this a hobby.  I will  keep you posted.
Posted: 01/21/14
07:57 PM
Good luck and patience will pay off in the end.
Posted: 01/21/14
11:15 PM
i helped a friend swap a 400 in place of a 301 a few years ago. i think we used the small a/c compressor but not 100% shur. i will ask him and try to get a look some time in the near future.
we were able to use the 80 harness. not shur about the pin locations between the 2 harnesses. thats a good question for wayne!
beware new china motor mounts fit like crap!
don't forget the 7 blade clutch fan and a bigger radiator.
Posted: 01/22/14
03:19 PM
My 79 301 Formula now has a 75 455 in it, I used the stock 301 frame mounts (cushions) and the block brackets from the 455 (same as a 400 or 350 Pontiac). Although I haven't seen a 301T wiring harness, the only wires you need to worry about are the main HEI power lead (10guage, pink or red with a white connector), the tach lead, temp sensor(use the sender from the 301 to ensure compatibility with your gauges), oil pressure sender (again, reuse the 301 sender) and starter wires. I doubt you need to swap harnesses and if you did I would suggest the harness from a 79-81 non-computer Bird. Not certain about the a/c brackets, I don't recall if the 77-79 400 cars had the small style compressor or not. The 455 PS and alt brackets should work fine with the 80 PS pump (keep it especially if you have WS6 steering!).
Posted: 01/27/14
10:21 PM
sorry to get your hopes up it was the a6 compressor. you may be able to use the same a/c lines and buy a reman compressor to fit the older brackets. the a6 works better anyway!
MrFitz MrFitz
Posted: 01/31/14
05:05 AM
Lots to thik about while I wait for the temperature in my garage to get above 20
Thanks guys
MrFitz MrFitz
Posted: 03/27/14
07:38 PM
Ok my new Art Carr tranny arrived today and  I am ready to drop the engine in...what about the electronic spark controller?
Do I pull it out and bypass it and if so how?  I know all I need is a 12v source to my new HEI distributor but there are several wires going to the ESC.  If I pull it out will it cause any other problems?
thanks
