air cleaner
air cleaner
marbil marbil
New User | Posts: 45 | Joined: 04/13
Posted: 02/07/14
03:49 PM
I think I am on the right track, If my carb has the vent outside the intake I need an air cleaner with the extra hole and rubber grommet between the snorkels correct?
Going to a swap meet on Sunday so trying to confirm what to be looking for.
Thanks Bill
shyrgfuh70 shyrgfuh70
Posted: 02/07/14
03:59 PM
WHAT?
Posted: 02/07/14
04:30 PM
the only thing i can envision  is that he is installing the 71 455 into the 69 firebird he has stashed where we cannot see it.
but the 71 455 has a float bowl vent that sticks up thru the air cleaner bottom with a grommet on it..
you can see the TALL BOWL vent in this image above right up near the filter nut.
Quadrajet 4M Topcover Pontiacversion Zps8d861a46
don't cut the tall tube off.. it will leave the fuel vapors free to spill out to the outside of the carb..
there are a few GM applications with a 1 inch air cleaner spacer ring.. you might be able to find one
if you can find a 71 to 79 pontiac air cleaner housing you might be in luck...
i don't know what years fit that bowl vent..
71Pontiacdualsnorkelaircleaner Zps77301f76
marbil marbil
Posted: 02/08/14
08:41 PM
You got it Wayne, exactly what I was thinking, sorry I did not post any pics
Posted: 02/08/14
10:34 PM
if you cannot find a  proper fitting air filter.. its going to be easier to use some carb off a different GM car...  there are other 455 motors.. buick. olds.. caddy has 472 and 500 motors.. chevy 454..  all of these will be close to what you have.. so you can keep the inside of your engine clean..
this way you can always. swap back to the poncho spec carb when you run across a proper air filter..
this is just a thought.. i have not been at the swap meet you are thinking of visiting..
this is just a thought.. best of luck in your search for the filter housing of your choice..
i did see other dual inlet housings.. but even used . they were several hundred dollars..  and almost triple that new repop
Posted: 02/09/14
10:04 AM
I rebuilt a 1975 q-jet for my 75 455 (the original carb from the engine) and had the same issue. I'm running an early 70's single snorkel air cleaner without the hole. I just set the air cleaner in place and gently tapped the area where the vent is with a small hammer to mark it. I then used a 3/4" hole saw to make the hole and used a PCV grommet that I found at the parts store to seal it.
Addict | Posts: 3963 | Joined: 06/09
Posted: 02/11/14
05:25 AM
That's exactly what I did on an aftermarket Eddy air cleaner Steve. It also helps hold the whole thing in place.
Posted: 02/11/14
10:04 PM
steve what size hole saw?
Posted: 02/12/14
04:47 AM
I used a 3/4" hole saw but in hindsight a 5/8" would have been a better fit and could be fine tuned with a carbide bit in a die grinder. The 3/4 is a bit sloppy.
