Throttle Cable
Throttle Cable
big-g-67gto big-g-67gto
Guru | Posts: 913 | Joined: 07/10
Posted: 02/26/14
08:55 AM
Would any of you folks know the length of a 4bl. throttle cable vs. a 2bl cable?
I am working on a 74 Grand Am, some where along the line the original throttle cable was replaced with an after market cable which is way to long and looks like h.s.  Got a line on a cable but the guy is not sure if the cable he has is for a 4bl or a 2bl set up.....
I got that Tin Indian GRIN!!
Posted: 02/26/14
11:44 AM
the only listing for 74 pontiacs..
Brand: ATP
Manufacturer's Part Number: Y194
Part Type: Throttle Cables
Product Line: ATP Accelerator Cables
Summit Racing Part Number: ATP-Y194
Cable Length (in): 20.250 in.
there is a trick... get the image up.. and go thru each cable image .. looking for length and end fittings..
you can also find an ATP catalog online..  i seem
Bonneville, Catalina & Safari Wagon 1977-81 231 All Y-263 19.50
1982-87 231-A All Y-211 22.75
1981 260-F All Y-215 23.00
1982 267 All Canada Y-211 22.75
1977-79 301 All Y-264 24.50
1980 301-W All Y-264 24.50
1980 305-H All Y-208 21.25
1982 305-H All Canada Y-266 23.50
1983-87 305-H All Y-266 23.50
1977 305-U All Y-266 23.50
1981 307 All Y-215 23.00
1986-89 307-Y All Y-215 23.00
1980-84 350-N All 25 mm OD Bushing on
Pump End of Cable Y-218 30.50
1977-79 350-R All Y-211 22.75
1980 350-R All Y-215 23.00
1982 4.1-4 All Y-211 22.75
1980 4.3-S All Y-264 24.50
1981 4.3-S All Y-369 26.50
1986-87 4.3-Z All Y-207 20.75
1977-79 403-M All Y-211 22.75
Firebird 1982-83 151-2 All Y-374 45.05
1977-81 231-A All Y-206 21.25
1976-77 250 All Y-264 24.50
1981 267 All Canada Y-196 22.00
Firebird (Cont'd) 1981 301-W All Y-369 26.50
1982-83 305 All Y-373 44.00
1981 305-H All Canada Y-196 22.00
1976-80 305-U All Y-196 22.00
1976-79 350-L All Y-196 22.00
1976-77 350-R All Y-264 24.50
1981 4.9-T All Y-369 26.50
1976-77 403-M All Y-264 24.50
1988-92 5.0-E All Y-755 29.10
Grand Am - See LeMans
Grand Prix 1981 229 All Y-207 20.75
1979-87 231 All Y-211 22.75
1976 250 All Y-277 23.75
1976 260 All Y-197 22.75
1978 260 All Y-266 23.50
1981 260-F All Y-214 23.75
1981-82 267 All Canada Y-211 22.75
1981 301 All Y-266 23.50
1978-80 305-H All Y-266 23.50
1981-82 305-H All Canada Y-266 23.50
1976 350 All w/2 B/C Y-201 20.50
1978-80 350-L All Y-266 23.50
1981-84 350-N All Diesel Y-218 30.50
1977 350-R All Y-197 22.75
1981 4.3-S All Y-266 23.50
1976 400 All w/2 B/C Y-201 20.50
1977 403 All Y-197 22.75
1975 All All w/2 B/C Y-201 20.50
1975 All All w/4 B/C Y-195 21.50
LeMans & Grand Am 1980-81 229 All Y-207 20.75
1978-81 231 All Y-211 22.75
1981 267 All Canada Y-211 22.75
1981 301-W All Y-266 23.50
1981 305-H All Canada Y-266 23.50
1977 305-U All Y-277 23.75
1978 305-U All Y-211 22.75
1981 350-N All Diesel Y-218 30.50
LeMans & Grand Am (Cont'd) 1975 All All w/2 B/C Y-201 20.50
Parisienne 1983 229 All Exc. Station Wagon Y-216 19.00
1983-84 231-A All Exc. Station Wagon Y-263 19.50
1985 231-A All Canada Y-263 19.50
1983-86 305-H All Y-208 21.25
1986-87 307-Y All Y-215 23.00
1983-85 350-N All Diesel Y-218 30.50
1985-86 4.3-Z All Y-216 19.00
Phoenix & Ventura 1980-81 151 All Y-212 35.75
1982-84 2.5-5 All Y-212 35.75
1980-84 2.8 All Y-193 30.75
1977-79 231 All Y-198 19.25
1974-75 250 All Exc. Integral Cyl. Head Y-194 20.25
1976 250 All Y-202 20.00
1977-79 305-U All Y-203 21.00
1972-74 350 All w/2 B/C Y-194 20.25
1977-79 350-L All Y-203 21.00
Posted: 02/26/14
01:15 PM
thanks Wayne, looks like I need a 21 1/2" cable...
Posted: 02/26/14
09:56 PM
why not measure what length cable casing you need.. from the fire wall to the bracket..  plus half an inch on each end..   some slack so the engine can rock without breaking the cable casing..
then measure from the casing to the throttle lever mounting..  and inside about an inch or so..
this will give you a rough idea..
the 4 barrel versions were longer. from the engine end mounting to carb linkage end..
i forgot to post that the first cable seems to be for the Nova/omega/ventura/apollo.
i have been away from the computer all day out with friends.. i will try to get back and sort this if you need more info.. i just copied and pasted then dashed.. i so rarely get out and about ..
Posted: 02/28/14
09:17 AM
That is a great chart that you posted Wayne, even thou it does not post a length for 1974, it is the same cable 73-75.  So 20 1/2" for a 2bl 21 1/2" for the 4bl. That cable is the same for LeMans, A Body GTO (73), and Grand Am. So problem solved, my guy also had several cables in the correct length.
