Help with 400 heads
Help with 400 heads
Code400 Code400
New User | Posts: 34 | Joined: 02/13
Posted: 02/27/14
11:03 PM
Hey guys, I have '68 400 which appears to be stock. I'm basically pulling it to freshen it up and see what I have (I haven't had the car too long). I just pulled the heads (# 15) and it looks to have sealed power flat top pistons. The engine doesn't ping on 91 octane with these heads? Anyway, I'd like to throw a cam, lifters, timing chain in and planned on ditching these heads for some screw in stud large valve. What do you guys think? See the pics, have these heads been worked and had the larger valves installed already? I can't tell. The engine runs great with good power but I've gone this far and wanna tinker around on it, learning at the same time for a future build. I have a line on 670's, #62's, or ??  heads.
I do not plan on a rebuild right now, just want a mild to mean street machine. Even with the high compression I'm not too worried as 100 octane is available near by. Thanks!
1967 Firebird 400
'68 400 engine
TH400
373 posi
Download?Mid=2 0 0 1 2088851 Apzci2iaacnxuxakrqzpy1q61%2B0&Pid=2&Fid=Inbox&Inline=1
https://us-mg6.mail.yahoo.com/ya/download?mid=2_0_0_1_2088095_AGLci2IAAKejUxAkFgvEonqJRls&pid=2&fid=Inbox&inline=1
Code400
1967 Firebird 400
TH400
3.73
Code400 Code400
Posted: 02/27/14
11:29 PM
UPDATE: after cleaning the pistons I can now see the .060 over mark. Now I really need some advice on head choice and no wonder the #15's aren't causing it to ping.  Any suggestions for heads and cam combo for running 91 octane? Thanks
Code400
1967 Firebird 400
TH400
3.73
Posted: 03/02/14
04:53 AM
Code,
your link to the pictures seems to be a dean end..
Guru | Posts: 1276 | Joined: 11/09
Posted: 03/02/14
06:25 AM
Are your pistons dish pistons ? 60 over pistons will give you more compression than stock pistons .
Code400 Code400
Posted: 03/02/14
10:12 AM
Sealed power flat top .060 over pistons. That's right, larger displacement would mean higher compression. How did this engine survive running on 91? Actually the previous owner said he ran 89 octane, he didn't know *** about the motor...This is why I wanted to get it out and see what I had. So, they are indeed 1968 #15 heads 72cc. Anyway, I guess I'll look for some 6X-4 heads and throw a cam in.... Any recommendations? I've read a million posts on cams but the .060 over throws me off a bit Confused . Thanks!
Code400
1967 Firebird 400
TH400
3.73
Posted: 03/02/14
12:21 PM
does your 15 heads have the 68 date code? there is also a 1970 455 #15 head 87cc witch would help explain why the 400 doesn't ping.
Code400 Code400
Posted: 03/02/14
01:25 PM
No they're the 68's, I double checked.
Code400
1967 Firebird 400
TH400
3.73
Posted: 03/02/14
02:30 PM
ok. instead of buying another set of heads you could have some work done to the 15s to make them a better head.
the 62s are good heads with large valves and screw in studs but no harden seats for unleaded fuel.
i have a set of 62s on a 406 that i have run for almost 20 years without harden seats and it still runs strong. it's about 380 hp.
Posted: 03/02/14
03:01 PM
I would cc the heads and find out for sure if they are 72 cc heads .
Posted: 03/02/14
03:35 PM
+1 Jack that would be the only way for sure to tell what size the chambers are.
Code400 Code400
Posted: 03/02/14
06:25 PM
Icon QuotePontiacman8:
Yeah, I will do that. I tried to post a pic of the cc but no luck Mad Do you guys post them off your desktop/folder or does it have to be a link to a website?? I've never seen a process like this forum uses before Confused . Anyway, it would be nice to post because these #15's have been worked in the past but I'm a novice....
Thanks again Guy's!!
Code400
1967 Firebird 400
TH400
3.73
Code400 Code400
Posted: 03/03/14
06:23 PM
Hopefully these pix work??
https://www.facebook.com/photo.php?fbid=791859607509550&set=pb.100000565545198.-2207520000.1393895903.&type=3&src=https%3A%2F%2Ffbcdn-sphotos-d-a.akamaihd.net%2Fhphotos-ak-prn2%2Ft1%2F1912464_791859607509550_710898857_n.jpg&size=640%2C480
https://www.facebook.com/photo.php?fbid=791860984176079&set=a.791859690842875.1073741825.100000565545198&type=1
Code400
1967 Firebird 400
TH400
3.73
Posted: 03/03/14
10:20 PM
ok that pic of the piston exlpains why you can run 89 octane gas! they are not flat tops. that is a 15cc dished cast piston so your safe or stuck with 72cc heads! should be right around 9 to 1.
them are the same pistons i had in another 406 with a modern 068 style cam,#62 heads and 3.73 gears in a 76 formula. it had real good mid to top end power 2500 to 5200!
Code400 Code400
Posted: 03/03/14
10:45 PM
Icon QuoteROWSLEY:
Alright!! yeah I looked those pistons up and everything I found said flat top  Confused Shows how much I know, lol. Well at least I know where I'm at now! I haven't had heads worked on in years and even then it was just a clean up. What do you think it will cost to have larger valves and screw in studs done to the #15's?? maybe decked to bump up the compression a tad? Just a rough rough idea, I know all shops are different. I have a nice chunk a change to put in them, just can't go the extra mile for Eddy's, I'd like to keep it around or under $1000 . Cool
Code400
1967 Firebird 400
TH400
3.73
Posted: 03/04/14
12:01 AM
last heads i had done 500.00 for clean/inspect and all new valves. check the cc's first.
for every .05 milled = 1cc , .030 will get you about 9.4 if your heads are 72cc you may need to mill the intake as well. have some bowl and mild port work done if you can afford it!
