455 pontiac in 1979 TA, AC Brackets.
geneman geneman
New User | Posts: 2 | Joined: 04/14
Posted: 04/21/14
07:01 PM
Background:
I have a 1979 Trans AM that had a 403 olds engine and TH350 in it from the factory.  I have removed that old engine and acquired a 76 Pontiac 455 from someone and had a complete rebuild done on the engine.  I have the engine installed in the car, attached to the transmission ok, and got stalled on the plumbing.  I sent this off to a shop to get many things done and we are stuck on getting all the brackets setup on the front on the engine.  I have most of the brackets but cant figure out what I am missing.
I was lead to this site by google, as someone was asking about similar and got posts of the repair manual exploded view.  Does anyone have this?
Also, I have run into a number of issues so far, such as power steering pump clearance, fuel pump on the opposite side, shaker hood clearance, etc..  Anyone do the same and have any other tips?
Any assistance would be appreciated!
Posted: 04/21/14
09:23 PM
sure.. but in my opinion you did it the hard way... instead of going olds 403 to pontiac 455.. you should have gone directly to olds 455 which would have been an exact fit for everything..
franks pontiac parts has a web site with most of the brackets and pulleys you will need.. for your conversion..
let me see if i can find you something to assist you in selection..
firebird part illustrations book/67-76/1-i.pdf
firebird part book/67-76/1-p.pdf
Posted: 04/21/14
09:38 PM
oh... some of the 301 pontiac brackets will fit on the 455.. some will need to be redrilled as there are height differences in some areas..
http://www.frankspontiacparts.com/engineparts/pontiacengineparts.htm
post some images.. use photobucket..  or videos to youtube..
geneman geneman
Posted: 04/22/14
12:54 AM
Thanks for the links, I will check them out when I have more time.  Late here.
I wanted to have a Pontiac engine in the Pontiac.  Didn't want to go olds.  I usually never choose the easy route Smile
You don't happen to have a exploded view of the stock 455 pulleys do you?
Posted: 04/22/14
11:22 AM
yea...
try this page..
http://www.gmpartswiki.com/getpage?pageid=79225
click the thumb nail upper right to go to the next page..
here is a 77 to 81 301 motor..
http://www.gmpartswiki.com/getpage?pageid=79228
here is a 455 pontiac.. but it does not show all the pulleys..
http://www.gmpartswiki.com/getpage?pageid=79237
this single out of dozens of books has over 1000 pages..
Posted: 04/22/14
11:29 AM
this starts the 403 pulleys..
http://www.gmpartswiki.com/getpage?pageid=79151
if you find a part number on the page.. look at the bottom of the page for the part number in a link.. it will take you elsewhere to find out info ..
